HMIN_equation_write()
Writes an equation to HyperMesh.
void HMIN_equation_write(HM_entityidtype id, char type, float* constant, int Inode_len, HM_entityidtype *Inodes, int *Idofs, float *Icoeffs, HM_entityidtype Dnode, int Ddof, float* Dcoeff, HM_entityidtype loadcollectorid);
HyperMesh hminlib Function
- id
- The ID of the equation.
- equationtype
- The type of the equation, a user-defined value.
- constant
- The constant of the equation.
- Inode_len
- The number of independent nodes.
- Inodes
- The IDs of the independent nodes.
- Idofs
- The degrees of freedom associated with the independent nodes in the form (123456 or 135).
- Icoeffs
- The coefficients associated with the independent nodes (6 per node).
- Dnode
- Ddof
- The degree of freedom associated with the dependent node (may be set to 0).
- Dcoeff
- The coefficient associated with the dependent node (may be set to 0).
- loadcollectorid
- The collector where the equation should be placed.
None.
