HMIN_rigidwall_writemotion()
Writes a motion definition of a rigid wall.
HMIN_rigidwall_writemotion(HM_entityidtype id, unsigned char motiontype, double xcomp, double ycomp, double zcomp);
HyperMesh hminlib Function
- id
- The ID of the rigid wall.
- motiontype
- The type of motion. Use:
- 0 - None
- 1 - Velocity
- 2 - Displacement
- xcomp, ycomp, zcomp
- The x, y, z components of motion.
This command must be preceded by the HMIN_rigidwall_write() command. The ID must refer to an existing rigid wall.
None.
