HMIN_system_flush()
Sends the systems stored in the buffer to HyperMesh.
void HMIN_system_flush(void);
HyperMesh hminlib Function
None.
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Creates a valid system from three nodes and writes the information to HyperMesh.
Frees the memory associated with systems stored with HMIN_system_store().
Retrieves the first pointer to a system.
Retrieves the next pointer to a system.
Retrieves the pointer to a system.
Retrieves the number of stored systems.
Sets up a buffer to provide a work area for systems before transferring them to HyperMesh.
Writes a system to HyperMesh.
Transforms a system based on angles.
Creates a system at a node.
Defines an entity in another system after you have read in and transformed the entity in HyperMesh.
Sets the output system ID for an entity after you have read in and transformed the entity in HyperMesh.
Writes a system, accessed by a pointer to the system, to HyperMesh.
Writes construction axis and plane data for node-based system.
Writes data for node dependency to a system.
The list of deprecated hminlib functions, and the new functions to use.
The list of undocumented hminlib functions.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
ON THIS PAGE
None.
ON THIS PAGE
