hwIH3DExportOptions GetCompressionLevel
Gets the level of non-lossy compression.
hwIH3DExportOptions_handle GetCompressionLevel
Tcl Query
Returns a number between 0 and 9. A value of 0 indicates no compression. A value of 9 indicates maximum compression.
This command covers only non-lossy compression. The default value for the level is 7, which gives a good balance between speed and size-reduction. The better the compression, the slower the file may be to write.
mySessionName GetH3DExportOptionsHandle option_handle
option_handle GetCompressionLevelErrors
None.
