hwIH3DExportOptions GetWriteDisplayedComponents
Queries whether only visible components will be written.
hwIH3DExportOptions_handle GetWriteDisplayedComponents
Tcl Query
Returns true or false, depending on whether writing displayed components only is enabled.
Sometimes, only part of a model is of interest. The remainder of the model can then be rendered invisible by turing off components. In some cases, it is desireable to write out only the remaining portion of the model and the related results.
mySessionName GetH3DExportOptionsHandle option_handle
options_handle GetWriteDisplayedComponentsErrors
None.
