hwIH3DExportOptions SetMaxCompressionError
Sets the maximum margin of error allowed during compression.
hwIH3DExportOptions_handle SetMaxCompressionError value
Tcl Modify
Lossy compression trades data resolution for savings in space. This command allows you to set the maximum degree of lost resolution, as a fraction of the total data range (max - min). The default value is .001 (or .1%).
- value
- The maximum acceptable error fraction.
mySessionName GetH3DExportOptionsHandle option_handle
option_handle SetMaxCompressionError .002Errors
None.
