Create 3D Mesh
Explore the tools used to create 3D mesh.
Define meshing preferences.
Each element has an associated element configuration. An element configuration tells HyperMesh how to draw, store, and work with the element.
Solver cards supported for elements.
Use the Element Quality view to review element quality while simultaneously editing your model.
Explore the different types of 1D mesh you can create in HyperMesh.
Explore the different types of 2D mesh you can create in HyperMesh.
Explore the different types of 3D mesh you can create in HyperMesh.
Supported 3D elements.
Solids are closed volume of surfaces that can take any shape. Solids are three-dimensional entities that can be used in automatic tetra and solid meshing.
Explore the tools used to create solid mesh.
Explore the tools used to edit 3D mesh.
