Translators are utilities that are run from the command line of the operating system to convert various types of results
files into a format that the program can read. A table of the translators supplied with the programs appears below. Since
the program can read HyperMesh binary results files, the entire set of HyperMesh results translators is included.
Browsers provide a structured view of model data, which you can use to review, modify, create, and manage
the contents of a model. In addition to visualization, browsers offer features like search, filtering, and sorting,
which enhance your ability to navigate and interact with the model data.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Use PhysicsAI to build fast predictive models from CAE data. PhysicsAI can be trained on data with any physics or
remeshing and without design variables.
Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
Translators
Translators are utilities that are run from the command line of the operating system to convert various types of results files into a format that the program can read. A table of the translators supplied with the programs appears below. Since the program can read HyperMesh binary results files, the entire set of HyperMesh results translators is included.
General Interfacing Aspects
Learn about MotionView interfacing with solvers, MotionView SolverMode, and how to execute solvers.
Interfacing with Abaqus
Overview of how the MotionView applications interface with the Abaqus solver.
Interfacing with ADAMS
Overview of how the MotionView applications interface with the ADAMS solver.
