Browsers provide a structured view of model data, which you can use to review, modify, create, and manage
the contents of a model. In addition to visualization, browsers offer features like search, filtering, and sorting,
which enhance your ability to navigate and interact with the model data.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Use PhysicsAI to build fast predictive models from CAE data. PhysicsAI can be trained on data with any physics or
remeshing and without design variables.
Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
From the HyperGraph menu, select Radar
Chart to display the Radar Chart ribbon.
You can use HyperGraph to plot vector, phase versus
magnitude, and radar plots. Use radar plots to plot complex data. The phase axis for
a radar plot is equivalent to the phase axis for a complex plot. The mag-axis for a
polar plot is equivalent to the magnitude axis for a complex plot. The key
differences are plotted polar coordinates - only a single frequency is
displayed.
Define
Edit existing curves and add new curves to the current plot.
Values
Retrieve individual point data on any curve in the active window. When a point is selected, the point data is displayed on the panel.
Datums
Add horizontal and vertical datum lines to plots.
