Explorations
An exploration is a multi-run simulation. Each exploration includes input design variables, and output responses. Explorations may also include goals, consisting of an objective and constraints.
Create Explorations
Use the Create Explorations tool to create DOE or optimization explorations.
*There are two ways to perform optimizations. Creating a “direct” optimization as described above creates an optimization exploration which will evaluate responses directly from the results of each solver run.
In addition, optimizations can be performed based on DOE explorations. In this case, responses are evaluated based on the response surface fit created automatically for each DOE. To create a DOE-based optimization, either check Optimize while evaluating the DOE or choose Optimize from the right-click context menu for a selected DOE exploration.
