Use the External Video Decoder
- Obtain the ffmpeg or mplayer (see Prerequisites for more information).
- From the [install_directory]/hw/prefinc folder, view the preferences_video.mvw file and verify that the *ExternalConverter() command is present and that a batch (Windows) or script file (Linux) exists in the location specified by the command. By default, this file will be named ffmpeg_codec_converter.
- Edit the file located in the path from the *ExternalConverter() statement. For Windows, edit the file with a BAT extension. The default command in the ffmpeg_codec_converter command is c:\\zvideo\\ffmpeg_converter\\ffmpeg -i %1 -y -vcodec mjpeg %2. You will need to replace the path ahead of ffmpeg with the path where your ffmpeg.exe is located. See the Relevant Statements section for more information.
- Start MediaView and attempt to open a video file that was unreadable in version 10.0 or older.
- When prompted, click Yes to start the external conversion process.
- You should soon see your video in MediaView (version 11.0 or later).
