FMU Entity
MotionView supports reading an FMU through the FMU entity.
See the FMU topic for additional information regarding adding, viewing, editing, and connecting an FMU entity to a model.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multibody dynamics models.
Add an FMU to the model or export a model as an FMU.
Learn about how you can leverage Functional Mockup Units (FMUs) to couple your MBS model with external solvers or processes to perform co-simulation or couple systems.
Reference material for the scripting interface which is a set of Tcl/Tk commands.
