Front Suspension Systems
Front suspension systems support the wheels in the front with the help of strut rods.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multibody dynamics models.
Add an FMU to the model or export a model as an FMU.
The vehicle library is installed as a part of the normal MotionView installation.
Rear Suspension systems support the rear wheel with the help of a swingarm and coil springs.
A powertrain based on a linear curve where the torque generated is directly proportional to throttle applied.
Jounce and Rebound bumpers restrict the upward and downward movement of suspension components.
Rider plays an important role in two wheeler dynamics. To capture the effects of rider on a vehicle, it is important to have a good human body multibody dynamics model.
The driveline transmits the power from the power source to the driving wheel.
Reference material for the scripting interface which is a set of Tcl/Tk commands.
