Full Vehicle Models with Altair Driver and Events
This section describes how to add a full vehicle model with the Altair Driver and include the events. The events are simulation commands that enable the Altair Driver control to perform the vehicle maneuvers. A model with an event exports an Altair Driver File (.adf) and the MotionSolve (.xml) files to be simulated.
Building a Vehicle Model with Altair Driver
In MotionView, models are assembled from libraries of pre-defined systems using the Assembly Wizard. The Assembly Wizard dialog guides you through the assembly process to build a full vehicle with the Altair Driver.
Vehicle Libraries and Assembly
Adding Events to the Model
