Spindle Length and Offset
Request Number: 80000270
| .plt Files | .abf, .mrf Files | Component | Unit | Comment |
| F1 | RESULT(1) | Not Used | Not Used | Not Used |
| F2 | RESULT(2) | Left Spindle Length | mm | The true left spindle length or the distance between the left wheel center and the point on the spindle which is closest to the kingpin axis. |
| F3 | RESULT(3) | Right Spindle Length | mm | The true right spindle length or the distance between the right wheel center and the point on the spindle which is closest to the kingpin axis. |
| F4 | RESULT(4) | Average Spindle Length | mm | The mean of the left and right spindle length. |
| F5 | RESULT(5) | Not Used | Not Used | Not Used |
| F6 | RESULT(6) | Left Spindle Offset | mm | The true left spindle offset or the minimum distance between the left spindle axis and the left kingpin axis. |
| F7 | RESULT(7) | Right Spindle Offset | mm | The true right spindle offset or the minimum distance between the right spindle axis and the right kingpin axis. |
| F8 | RESULT(8) | Average Spindle Offset | mm | The mean of the left and right spindle offset. |
