Browsers provide a structured view of model data, which you can use to review, modify, create, and manage
the contents of a model. In addition to visualization, browsers offer features like search, filtering, and sorting,
which enhance your ability to navigate and interact with the model data.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Use PhysicsAI to build fast predictive models from CAE data. PhysicsAI can be trained on data with any physics or
remeshing and without design variables.
Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
The rolling systems represent the components where the track
is usually wrapped around. They are necessary for the track builder to identify the path of
the track. The figure below shows the Create rolling system dialog. Figure 1. Create rolling system dialog
Six different rolling systems are available to be used in the track builder,
Sprocket, Double Sprocket, Idler, Roller, Wheel, and Double Wheel.
Sprockets/Double Sprocket
Profiled wheel with teeth, or cogs, that mesh with a track.
Idler
A wheel that is used to alter the path of the track or to increase the wrap
angle.
Roller
A small wheel used to prevent the catenary hang of the track and support the load of
the track.
Wheel/ Double Wheel
Transfers the vehicle weight to the track.
The symmetric pair option enables the creation of two
rolling systems representing a pair symmetry to the X-Z plane.
Note: The created pair systems are not MotionView pair entities,
but systems duplicated and positioned in the symmetric plane. The symmetric pair option is
not recommended to represent a double system in the same track, when that representation
is needed, use the double sprocket or double wheel instead of single wheel with the
symmetric pair option.
The Rolling elements are built as a combination of
primitive geometries. The Use CAD/H3D graphics for rolling element
option enables adding CAD or H3D Graphics to the rolling system. Based on the symmetric pair
option, the CAD graphics can be added in the left of right side of the rolling element.
Note: To properly position CAD graphics in the rolling system, make sure
the center of the CAD graphics is positioned at the global origin (0,0,0 in XYZ
coordinate) before including in the rolling system.
Mass and inertia for the
rolling system are calculated based on the provided geometric dimensions or CAD Graphics.
Alternatively, user-defined mass and inertia can be provided using the option
User mass, inertia rolling element, in this case the rolling
systems bodies must be edited to include the mass and inertia properties.
The
properties of the rolling system can be modified in the dataset under the rolling system
after the system has been created.
