Browsers provide a structured view of model data, which you can use to review, modify, create, and manage
the contents of a model. In addition to visualization, browsers offer features like search, filtering, and sorting,
which enhance your ability to navigate and interact with the model data.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Use PhysicsAI to build fast predictive models from CAE data. PhysicsAI can be trained on data with any physics or
remeshing and without design variables.
Create and edit user-defined data type expressions, derived load cases, and systems. You can also plot a forming limit
diagram, generate streamlines, track entities during animation, and create and import/export sets of entities.
Query entities, create or edit free body diagrams, construct multiple curves and plots from a single result file, and
create and plot stress linearization.
Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
The management of Free Body Diagrams (FBD) sections created in
HyperView can be handled by means of their storage and retrieval
through an ASCII file statement, allowing you to manipulate the definition of such items
directly in the input/output process.
Once you have defined FBD sections in HyperView, you can invoke the Export dialog (shown below), where you
can select which sections are to be exported.
From the Aerospace menu, select FBD > Export FBD Sections. Figure 1.
The export formats supported are:
XML
CSV
Once the section file has been created, it can be shared and re-used on models
having the same topology or it can be modified to change the original section
definition.
The Import option works accordingly supporting the same input file
definition (.csv, .xml). Figure 3.
