Perspective
The Perspective option allows you to display graphics using true 3-D perspective.
Figure 1. Perspective Option
A graphical manipulator allows you to modify specific items directly in the graphics area using interactive tools.
HyperView supports stereoscopic 3D viewing to visualize simulation data in 3D.
HyperView uses scalable fonts for Linux to render text in the 3D window.
A right-click in the graphics area displays a context menu which provides access to various options is available in HyperView.
The Active Model feature allows you to cut, copy, or paste the active model into another window.
The Apply Style option also allows you to select and apply display attributes of the active model in the current window to all models available in the current window, the current page, all pages, or selected HyperView windows in the session.
The Boundary Geometry option allows you to visualize the boundaries of the model regardless of whether or not entities are displayed.
Record View allows you to record the current view in the HWC Console and HWC log file.
A new workflow emphasizing the multicore profile for standard crash post processing use cases.
