Add a Note
From the Annotate tools, click the Notes tool.
Figure 1. -
To attach the note to a specific entity type, use the guide bar drop-down menu to select the entity type
(Nodes, Elements,
Components, or Systems).
Figure 2. - Click on the entity where you would like to create a note or click in an empty space to create a free-floating note.
- Drag and drop the note that you just created to place it anywhere in the modeling window.
