Compare Models
Use the Compare Models tool to compare the difference between two decks (ID comparison runs through offset).
- From the menu bar, click .
- Select the Reference file and Target file.
- Click Import Files.
Select the Method.
- Global: Comparison is performed showing the overall model characteristics.
- Local: Comparison on either nodes or elements is performed selecting the associated attributes/data names. Levels of tolerance can be set up. You can highlight selected entities, report, create a set, import into the Matrix Browser, display marker or scalar plot.
- Click Perform Comparison.
