Create Property By Element ID
Use the Create Properties/Beam sections For Each Element tool to create a new property with the same ID as the element by copying the existing 1D and 2D element property and assigning it to the component/part.
This is useful for creating a GFEM-global FE model for size and beam section optimization using the design explorer (DSVAR shell thickness and standard beam section dimensions for every element).
