Control Nodal Coordinate Precision (Rounding Off)
Round off the node coordinates (multiple nodes) to the desired precision and update the HyperMesh database.
From the menu bar, click .
Create an assembly structure from a .csv file definition.
Use the Coordinates Precision Control tool to control the node precision in the Nastran/OptiStruct output decks (GRID) card.
Use the Nodal Equivalence tool to select the node location to perform direct nodal equivalence instead of running it through either component or element selection.
From the menu bar, click Aerospace > Nodes > Precision Control.
