Export a HDF5 File
- Import the model and result file in HyperMesh.
 - From the menu bar, click Aerospace > Export > HM-HDF5.
 - Select the export directory path.
                Select the Schema Type.
                Nastran is the default. If you select custom you can select a custom Schema File.
 - Use the Elements Selector to select elements from the model.
 - Select the subcases, if available, from the Subcase List.
                Click Export.
                The HDF5 file is exported.
 - Click Close to close the tool.
