Find and Display Sets that Contain Nodes/Elements
Select either elements or nodes from the model and find the sets that are collected.
Create an assembly structure from a .csv file definition.
Use the Quick Set tool to create relevant elements that are masked to ease further selection/generation.
Use the Boolean Operations tool to list elements and create new sets.
