Traditional Methods
Composite stress toolbox functionality which supports calculation of engineering constants, compliance and stiffness matrices, parameterized joint and panel analysis, and other traditional hand-calculation methods.
Pre-processing in HyperMesh.
Composite stress toolbox functionality.
ESAComp is software for analysis and design of composites.
Development of multiscale and single scale material models and simulation of parts manufactured from any heterogeneous and homogenous material.
ON THIS PAGE
ON THIS PAGE
