Rotor Dynamics
Rotor Dynamics is the analysis of structures containing rotating components.
The dynamic behavior of such structures is influenced by the type and angular velocity of rotating components and their locations within the model. Rotor dynamics is available in OptiStruct for modal frequency response, complex eigenvalue, static, linear direct transient and small displacement nonlinear direct transient analyses.
OptiStruct supports both 1D and 3D rotors for Rotor Dynamic Analysis.
Motivation
When a component within the structure rotates, additional forces like the gyroscopic force and circular damping force act on it. It is important to determine the effects of rotating components on the system as a whole. The natural frequencies of a system usually change, if gyroscopic forces act on the model due to a rotating component. Circulating damping forces due to rotating components can lead to system instability. These forces are a function of the frequency of rotating component. In OptiStruct, they are included in the calculation of the response of the structure of interest when required in applicable subcases.
Figure 1. Application of Rotor Dynamics Analysis
In Figure 1, the rotating components of the structure are the shafts on which gears are mounted. The design of the rotors and their angular frequencies can affect the dynamic response of the structure. Any design will most likely lead to asymmetrical mass distribution about the rotor axes. This unbalanced mass, even if it is not significant, can result in deflection of the rotor depending on various factors. The magnitude of these deflections will be augmented when the rotating speed of the shafts equals the natural frequency of the structure (Resonance), and can lead to catastrophic failure of the system.
Implementation
The Rotor Dynamics functionality is activated in OptiStruct with the use of the RGYRO Subcase Information Entry (RGYRO=ID). This RGYRO entry references the identification number of a RGYRO Bulk Data Entry. Related Bulk Data Entries, RSPINR, UNBALNC, ROTOR/ROTORG and RSPEED are defined in the model for Rotor Dynamics. Parameters PARAM,GYROAVG, PARAM,WR3, and PARAM,WR4 are also used.
Whirl
A rotor is a structure that rotates about its own axis at a specific angular velocity. If a lateral force is applied to the rotor, it will deform in the lateral direction. This deformation is dependent on various factors, such as, magnitude of the applied force, rotor material properties, stator stiffness, and damping within the system. Due to rotor rotation, the deformed rotor will also whirl about an axis.
Synchronous and Asynchronous Analysis
The whirling speed can either be the same as rotor speed or it can be different from it. The type of analysis performed if the whirling speed and the rotor speed match is known as synchronous analysis. If the speeds do not match, then asynchronous analysis is used to determine the dynamic response of the model. In OptiStruct, the RGYRO Bulk Data Entry can be used to select synchronous/asynchronous analysis.
Figure 2. Types of Whirl and the Two Analysis Types that are Dependent on the Angular Frequency of a Rotor
Forward Whirl and Backward Whirl
The type of whirl depends on the spin direction of a rotor. If the rotor spin direction is the same as that of its whirl direction, then it is termed as forward whirl. If the rotor spin direction is opposite to the whirl direction, it is termed as backward whirl. In complex eigenvalue analysis, you can determine and differentiate between the modes of a structure undergoing backward whirl and forward whirl.
Supported Solution Sequences
OptiStruct supports the Rotor Dynamics functionality in the following solution sequences.
Frequency Response Analysis
The response of a structure with rotating components to a specified external excitation can be determined using the rotor dynamics functionality in frequency response analysis.
Asynchronous Analysis (RGYRO=ASYNC)
If ASYNC is specified in the RGYRO Bulk Data Entry, the rotors within the structure have user-defined spin rates. The excitation frequency (FREQi Bulk Data Entries) is independent of the reference rotor speed defined in the RGYRO Bulk Data Entry.
Synchronous Analysis (RGYRO=SYNC)
If SYNC is specified in the RGYRO Bulk Data Entry, the reference rotor spin rate is equal to (or synchronous with) the excitation frequency. The reference rotor speed is not input via the RGYRO Bulk Data Entry and the FREQi Bulk Data Entries values are used in this analysis.
Complex Eigenvalue Analysis
The eigenvalues and critical speeds of a structure with rotating components can be determined using the rotor dynamics functionality in complex eigenvalue analysis.
If ASYNC is specified in the RGYRO Bulk Data Entry, the rotors within the structure have user-defined spin rates via the RSPEED entry and the Campbell Diagram can be plotted to find the critical speeds. Additionally, since the calculated eigenvalues are complex, you can determine unstable modes by studying the real parts of the calculated eigenvalues. If the real part of a complex eigenvalue is positive, then the corresponding system mode is unstable.
If SYNC is specified in the RGYRO Bulk Data Entry, only the critical speeds are calculated as the rotor speeds are equal to the whirl frequencies. These critical speeds can lead to structural resonance and the design should be modified to change its whirl frequencies or the operating rotor spin rate should be limited to avoid reaching the critical speeds.
Note: In a Frequency Response Analysis, the Synchronous Analysis (SYNC) option is generally used to model rotors with an inherent unbalance. The rotor unbalance can be specified as a force or via the UNBALNC Bulk Data Entry. The analysis is synchronous because the unbalanced load vibrates at the whirl frequency of the system which is equal to the rotor spin speed.
Frequency Response Analysis (ASYNC)
Asynchronous Analysis is activated using the RGYRO=ASYNC option. Frequency Response Analysis in rotor dynamics involves defining the excitation either as an external varying load as a function of frequency or as a rotor unbalance via the UNBALNC Bulk Data Entry (or as a force that simulates the effect of the rotor unbalance). Asynchronous frequency response analysis in OptiStruct is designed for an external varying force at a specific set of frequencies. The following equation implements the external loading functionality in OptiStruct. The rotor speeds should be specified by you for Asynchronous Frequency Response Analysis.(1) − ω 2 M+iω C S + α s1 M S + α s2 K S + C SH + 1+iG K S +i C SM +i C SHM + ∑ j=1 N 1+i GR j K R j +i C RM j +i C RHM j +iω α R1 M R + α R2 K R + C R + C RH j + Ω R j iω C RG j + C R C j + C RH C j + α R1 M R C + α R2 K R C j + GR ω K R C j + 1 ω C RHM C j + C RM C j u ω =f ω MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaadaqadaabaeqabaGaeyOeI0IaeqyYdC 3aaWbaaSqabeaacaaIYaaaaOGaaCytaiabgUcaRiaadMgacqaHjpWD daqadaqaaiaahoeadaWgaaWcbaGaam4uaaqabaGccqGHRaWkcqaHXo qydaWgaaWcbaGaam4CaiaaigdaaeqaaOGaaCytamaaBaaaleaacaWG tbaabeaakiabgUcaRiabeg7aHnaaBaaaleaacaWGZbGaaGOmaaqaba GccaWHlbWaaSbaaSqaaiaadofaaeqaaOGaey4kaSIaaC4qamaaBaaa leaacaWGtbGaamisaaqabaaakiaawIcacaGLPaaacqGHRaWkdaqada qaaiaaigdacqGHRaWkcaWGPbGaam4raaGaayjkaiaawMcaaiaahUea daWgaaWcbaGaam4uaaqabaGccqGHRaWkcaWGPbGaaC4qamaaBaaale aacaWGtbGaamytaaqabaGccqGHRaWkcaWGPbGaaC4qamaaBaaaleaa caWGtbGaamisaiaad2eaaeqaaaGcbaGaey4kaSYaaabCaeaadaqada abaeqabaWaaeWaaeaacaaIXaGaey4kaSIaamyAamaabmaabaGaam4r aiaadkfaaiaawIcacaGLPaaadaWgaaWcbaGaamOAaaqabaaakiaawI cacaGLPaaadaqadaqaaiaahUeadaWgaaWcbaGaamOuaaqabaaakiaa wIcacaGLPaaadaWgaaWcbaGaamOAaaqabaGccqGHRaWkcaWGPbWaae WaaeaacaWHdbWaaSbaaSqaaiaadkfacaWGnbaabeaaaOGaayjkaiaa wMcaamaaBaaaleaacaWGQbaabeaakiabgUcaRiaadMgadaqadaqaai aahoeadaWgaaWcbaGaamOuaiaadIeacaWGnbaabeaaaOGaayjkaiaa wMcaamaaBaaaleaacaWGQbaabeaakiabgUcaRiaadMgacqaHjpWDda qadaqaaiabeg7aHnaaBaaaleaacaWGsbGaaGymaaqabaGccaWHnbWa aSbaaSqaaiaadkfaaeqaaOGaey4kaSIaeqySde2aaSbaaSqaaiaadk facaaIYaaabeaakiaahUeadaWgaaWcbaGaamOuaaqabaGccqGHRaWk caWHdbWaaSbaaSqaaiaadkfaaeqaaOGaey4kaSIaaC4qamaaBaaale aacaWGsbGaamisaaqabaaakiaawIcacaGLPaaadaWgaaWcbaGaamOA aaqabaaakeaacqGHRaWkdaqadaqaaiabfM6axnaaBaaaleaacaWGsb aabeaaaOGaayjkaiaawMcaamaaBaaaleaacaWGQbaabeaakmaabmaa eaqabeaacaWGPbGaeqyYdC3aaeWaaeaacaWHdbWaaSbaaSqaaiaadk facaWGhbaabeaaaOGaayjkaiaawMcaamaaBaaaleaacaWGQbaabeaa kiabgUcaRmaabmaabaGaaC4qamaaDaaaleaacaWGsbaabaGaam4qaa aaaOGaayjkaiaawMcaamaaBaaaleaacaWGQbaabeaakiabgUcaRmaa bmaabaGaaC4qamaaDaaaleaacaWGsbGaamisaaqaaiaadoeaaaaaki aawIcacaGLPaaadaWgaaWcbaGaamOAaaqabaGccqGHRaWkdaqadaqa aiabeg7aHnaaBaaaleaacaWGsbGaaGymaaqabaGccaWHnbWaa0baaS qaaiaadkfaaeaacaWGdbaaaOGaey4kaSIaeqySde2aaSbaaSqaaiaa dkfacaaIYaaabeaakiaahUeadaqhaaWcbaGaamOuaaqaaiaadoeaaa aakiaawIcacaGLPaaadaWgaaWcbaGaamOAaaqabaaakeaacqGHRaWk daWcaaqaaiaadEeacaWGsbaabaGaeqyYdChaamaabmaabaGaaC4sam aaDaaaleaacaWGsbaabaGaam4qaaaaaOGaayjkaiaawMcaamaaBaaa leaacaWGQbaabeaakiabgUcaRmaalaaabaGaaGymaaqaaiabeM8a3b aadaqadaqaamaabmaabaGaaC4qamaaDaaaleaacaWGsbGaamisaiaa d2eaaeaacaWGdbaaaaGccaGLOaGaayzkaaWaaSbaaSqaaiaadQgaae qaaOGaey4kaSYaaeWaaeaacaWHdbWaa0baaSqaaiaadkfacaWGnbaa baGaam4qaaaaaOGaayjkaiaawMcaamaaBaaaleaacaWGQbaabeaaaO GaayjkaiaawMcaaaaacaGLOaGaayzkaaaaaiaawIcacaGLPaaaaSqa aiaadQgacqGH9aqpcaaIXaaabaGaamOtaaqdcqGHris5aaaakiaawI cacaGLPaaacaWH1bWaaeWaaeaacqaHjpWDaiaawIcacaGLPaaacqGH 9aqpcaWHMbWaaeWaaeaacqaHjpWDaiaawIcacaGLPaaaaaa@F08E@
The response of a system with rotating components to an external load in the frequency domain is calculated based on Equation 1.
Frequency Response Analysis (SYNC)
Synchronous Analysis is activated using the RGYRO=SYNC option. Frequency Response Analysis in rotor dynamics involves defining the excitation either as an external varying load as a function of frequency or as a rotor unbalance via the UNBALNC Bulk Data Entry (or as a force that simulates the effect of the rotor unbalance). Synchronous Frequency Response Analysis in OptiStruct is designed to calculate the response of a system with a rotor unbalance. The following equation implements the rotor unbalance functionality in OptiStruct. The rotor speeds are determined from the FREQi entries for Synchronous frequency response analysis.(2) − Ω ref 2 M−i ∑ j=1 N β j C RG j +i Ω ref C S + α s1 M S + α s2 K S + C SH + 1+iG K S +i C SM +i C SHM + ∑ j=1 N 1+i GR j K R j +i C RM j +i C RHM j +i Ω ref α R1 M R + α R2 K R + C R + C RH j + α j + Ω ref β j +i Ω ref α j C RG j + C R C j + C RH C j + α R1 M R C + α R2 K R C j + GR Ω ref K R C j + 1 Ω ref C RHM C j + C RM C j u Ω ref =f Ω ref MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaadaqadaabaeqabaGaeyOeI0IaeuyQdC 1aa0baaSqaaiaadkhacaWGLbGaamOzaaqaaiaaikdaaaGcdaqadaqa aiaah2eacqGHsislcaWGPbWaaabCaeaacqaHYoGydaWgaaWcbaGaam OAaaqabaGcdaqadaqaaiaahoeadaWgaaWcbaGaamOuaiaadEeaaeqa aaGccaGLOaGaayzkaaWaaSbaaSqaaiaadQgaaeqaaaqaaiaadQgacq GH9aqpcaaIXaaabaGaamOtaaqdcqGHris5aaGccaGLOaGaayzkaaGa ey4kaSIaamyAaiabfM6axnaaBaaaleaacaWGYbGaamyzaiaadAgaae qaaOWaaeWaaeaacaWHdbWaaSbaaSqaaiaadofaaeqaaOGaey4kaSIa eqySde2aaSbaaSqaaiaadohacaaIXaaabeaakiaah2eadaWgaaWcba Gaam4uaaqabaGccqGHRaWkcqaHXoqydaWgaaWcbaGaam4Caiaaikda aeqaaOGaaC4samaaBaaaleaacaWGtbaabeaakiabgUcaRiaahoeada WgaaWcbaGaam4uaiaadIeaaeqaaaGccaGLOaGaayzkaaGaey4kaSYa aeWaaeaacaaIXaGaey4kaSIaamyAaiaadEeaaiaawIcacaGLPaaaca WHlbWaaSbaaSqaaiaadofaaeqaaOGaey4kaSIaamyAaiaahoeadaWg aaWcbaGaam4uaiaad2eaaeqaaOGaey4kaSIaamyAaiaahoeadaWgaa WcbaGaam4uaiaadIeacaWGnbaabeaaaOqaaiabgUcaRmaaqahabaWa aeWaaqaabeqaamaabmaabaGaaGymaiabgUcaRiaadMgadaqadaqaai aadEeacaWGsbaacaGLOaGaayzkaaWaaSbaaSqaaiaadQgaaeqaaaGc caGLOaGaayzkaaWaaeWaaeaacaWHlbWaaSbaaSqaaiaadkfaaeqaaa GccaGLOaGaayzkaaWaaSbaaSqaaiaadQgaaeqaaOGaey4kaSIaamyA amaabmaabaGaaC4qamaaBaaaleaacaWGsbGaamytaaqabaaakiaawI cacaGLPaaadaWgaaWcbaGaamOAaaqabaGccqGHRaWkcaWGPbWaaeWa aeaacaWHdbWaaSbaaSqaaiaadkfacaWGibGaamytaaqabaaakiaawI cacaGLPaaadaWgaaWcbaGaamOAaaqabaGccqGHRaWkcaWGPbGaeuyQ dC1aaSbaaSqaaiaadkhacaWGLbGaamOzaaqabaGcdaqadaqaaiabeg 7aHnaaBaaaleaacaWGsbGaaGymaaqabaGccaWHnbWaaSbaaSqaaiaa dkfaaeqaaOGaey4kaSIaeqySde2aaSbaaSqaaiaadkfacaaIYaaabe aakiaahUeadaWgaaWcbaGaamOuaaqabaGccqGHRaWkcaWHdbWaaSba aSqaaiaadkfaaeqaaOGaey4kaSIaaC4qamaaBaaaleaacaWGsbGaam isaaqabaaakiaawIcacaGLPaaadaWgaaWcbaGaamOAaaqabaaakeaa cqGHRaWkdaqadaqaaiabeg7aHnaaBaaaleaacaWGQbaabeaakiabgU caRiabfM6axnaaBaaaleaacaWGYbGaamyzaiaadAgaaeqaaOGaeqOS di2aaSbaaSqaaiaadQgaaeqaaaGccaGLOaGaayzkaaWaaeWaaqaabe qaaiabgUcaRiaadMgacqqHPoWvdaWgaaWcbaGaamOCaiaadwgacaWG Mbaabeaakiabeg7aHnaaBaaaleaacaWGQbaabeaakmaabmaabaGaaC 4qamaaBaaaleaacaWGsbGaam4raaqabaaakiaawIcacaGLPaaadaWg aaWcbaGaamOAaaqabaGccqGHRaWkdaqadaqaaiaahoeadaqhaaWcba GaamOuaaqaaiaadoeaaaaakiaawIcacaGLPaaadaWgaaWcbaGaamOA aaqabaGccqGHRaWkdaqadaqaaiaahoeadaqhaaWcbaGaamOuaiaadI eaaeaacaWGdbaaaaGccaGLOaGaayzkaaWaaSbaaSqaaiaadQgaaeqa aOGaey4kaSYaaeWaaeaacqaHXoqydaWgaaWcbaGaamOuaiaaigdaae qaaOGaaCytamaaDaaaleaacaWGsbaabaGaam4qaaaakiabgUcaRiab eg7aHnaaBaaaleaacaWGsbGaaGOmaaqabaGccaWHlbWaa0baaSqaai aadkfaaeaacaWGdbaaaaGccaGLOaGaayzkaaWaaSbaaSqaaiaadQga aeqaaaGcbaGaey4kaSYaaSaaaeaacaWGhbGaamOuaaqaaiabfM6axn aaBaaaleaacaWGYbGaamyzaiaadAgaaeqaaaaakmaabmaabaGaaC4s amaaDaaaleaacaWGsbaabaGaam4qaaaaaOGaayjkaiaawMcaamaaBa aaleaacaWGQbaabeaakiabgUcaRmaalaaabaGaaGymaaqaaiabfM6a xnaaBaaaleaacaWGYbGaamyzaiaadAgaaeqaaaaakmaabmaabaWaae WaaeaacaWHdbWaa0baaSqaaiaadkfacaWGibGaamytaaqaaiaadoea aaaakiaawIcacaGLPaaadaWgaaWcbaGaamOAaaqabaGccqGHRaWkda qadaqaaiaahoeadaqhaaWcbaGaamOuaiaad2eaaeaacaWGdbaaaaGc caGLOaGaayzkaaWaaSbaaSqaaiaadQgaaeqaaaGccaGLOaGaayzkaa aaaiaawIcacaGLPaaaaaGaayjkaiaawMcaaaWcbaGaamOAaiabg2da 9iaaigdaaeaacaWGobaaniabggHiLdaaaOGaayjkaiaawMcaaiaahw hadaqadaqaaiabfM6axnaaBaaaleaacaWGYbGaamyzaiaadAgaaeqa aaGccaGLOaGaayzkaaGaeyypa0JaaCOzamaabmaabaGaeuyQdC1aaS baaSqaaiaadkhacaWGLbGaamOzaaqabaaakiaawIcacaGLPaaaaaa@2289@
The response of a system with rotating components to a rotor imbalance which is considered as a force acting in the frequency domain is calculated based on Equation 2.
Frequency Response Analysis with WR3, WR4 and WRH (ASYNC)
Parameters PARAM,WR3, PARAM,WR4, and PARAM,WRH can be used to avoid frequency dependent calculation of the rotor damping and circulation terms in systems with multiple rotors. The frequency values in the circulation damping terms are replaced with the values of the parameters as shown in Equation 3. PARAM,GYROAVG should be set to -1 to be able to bypass frequency dependent look-up and use the WR3, WR4, and WRH values.(3) − ω 2 M+iω C S + α s1 M S + α s2 K S + C SH + 1+iG K S +i C SM +i C SHM + ∑ j=1 N 1+iω GR WR3 K R j +iω 1 WR4 C RM j +iω 1 WRH C RHM j +iω α R1 M R + α R2 K R + C R + C RH j + Ω R j iω C RG j + C R C j + C RH C j + α R1 M R C + α R2 K R C j + GR WR3 K R C j + 1 WR4 C RM C j + 1 WRH C RHM C j u ω =f ω MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaadaqadaabaeqabaGaeyOeI0IaeqyYdC 3aaWbaaSqabeaacaaIYaaaaOGaaCytaiabgUcaRiaadMgacqaHjpWD daqadaqaaiaahoeadaWgaaWcbaGaam4uaaqabaGccqGHRaWkcqaHXo qydaWgaaWcbaGaam4CaiaaigdaaeqaaOGaaCytamaaBaaaleaacaWG tbaabeaakiabgUcaRiabeg7aHnaaBaaaleaacaWGZbGaaGOmaaqaba GccaWHlbWaaSbaaSqaaiaadofaaeqaaOGaey4kaSIaaC4qamaaBaaa leaacaWGtbGaamisaaqabaaakiaawIcacaGLPaaacqGHRaWkdaqada qaaiaaigdacqGHRaWkcaWGPbGaam4raaGaayjkaiaawMcaaiaahUea daWgaaWcbaGaam4uaaqabaGccqGHRaWkcaWGPbGaaC4qamaaBaaale aacaWGtbGaamytaaqabaGccqGHRaWkcaWGPbGaaC4qamaaBaaaleaa caWGtbGaamisaiaad2eaaeqaaaGcbaGaey4kaSYaaabCaeaadaqada abaeqabaWaaeWaaeaacaaIXaGaey4kaSIaamyAaiabeM8a3naabmaa baWaaSaaaeaacaWGhbGaamOuaaqaaiaadEfacaWGsbGaaG4maaaaai aawIcacaGLPaaaaiaawIcacaGLPaaadaqadaqaaiaahUeadaWgaaWc baGaamOuaaqabaaakiaawIcacaGLPaaadaWgaaWcbaGaamOAaaqaba GccqGHRaWkcaWGPbGaeqyYdC3aaeWaaeaadaWcaaqaaiaaigdaaeaa caWGxbGaamOuaiaaisdaaaaacaGLOaGaayzkaaWaaeWaaeaacaWHdb WaaSbaaSqaaiaadkfacaWGnbaabeaaaOGaayjkaiaawMcaamaaBaaa leaacaWGQbaabeaakiabgUcaRiaadMgacqaHjpWDdaqadaqaamaala aabaGaaGymaaqaaiaadEfacaWGsbGaamisaaaaaiaawIcacaGLPaaa daqadaqaaiaahoeadaWgaaWcbaGaamOuaiaadIeacaWGnbaabeaaaO GaayjkaiaawMcaamaaBaaaleaacaWGQbaabeaaaOqaaiabgUcaRiaa dMgacqaHjpWDdaqadaqaaiabeg7aHnaaBaaaleaacaWGsbGaaGymaa qabaGccaWHnbWaaSbaaSqaaiaadkfaaeqaaOGaey4kaSIaeqySde2a aSbaaSqaaiaadkfacaaIYaaabeaakiaahUeadaWgaaWcbaGaamOuaa qabaGccqGHRaWkcaWHdbWaaSbaaSqaaiaadkfaaeqaaOGaey4kaSIa aC4qamaaBaaaleaacaWGsbGaamisaaqabaaakiaawIcacaGLPaaada WgaaWcbaGaamOAaaqabaaakeaacqGHRaWkdaqadaqaaiabfM6axnaa BaaaleaacaWGsbaabeaaaOGaayjkaiaawMcaamaaBaaaleaacaWGQb aabeaakmaabmaaeaqabeaacaWGPbGaeqyYdC3aaeWaaeaacaWHdbWa aSbaaSqaaiaadkfacaWGhbaabeaaaOGaayjkaiaawMcaamaaBaaale aacaWGQbaabeaakiabgUcaRmaabmaabaGaaC4qamaaDaaaleaacaWG sbaabaGaam4qaaaaaOGaayjkaiaawMcaamaaBaaaleaacaWGQbaabe aakiabgUcaRmaabmaabaGaaC4qamaaDaaaleaacaWGsbGaamisaaqa aiaadoeaaaaakiaawIcacaGLPaaadaWgaaWcbaGaamOAaaqabaGccq GHRaWkdaqadaqaaiabeg7aHnaaBaaaleaacaWGsbGaaGymaaqabaGc caWHnbWaa0baaSqaaiaadkfaaeaacaWGdbaaaOGaey4kaSIaeqySde 2aaSbaaSqaaiaadkfacaaIYaaabeaakiaahUeadaqhaaWcbaGaamOu aaqaaiaadoeaaaaakiaawIcacaGLPaaadaWgaaWcbaGaamOAaaqaba aakeaacqGHRaWkdaWcaaqaaiaadEeacaWGsbaabaGaam4vaiaadkfa caaIZaaaamaabmaabaGaaC4samaaDaaaleaacaWGsbaabaGaam4qaa aaaOGaayjkaiaawMcaamaaBaaaleaacaWGQbaabeaakiabgUcaRmaa laaabaGaaGymaaqaaiaadEfacaWGsbGaaGinaaaadaqadaqaaiaaho eadaqhaaWcbaGaamOuaiaad2eaaeaacaWGdbaaaaGccaGLOaGaayzk aaWaaSbaaSqaaiaadQgaaeqaaOGaey4kaSYaaSaaaeaacaaIXaaaba Gaam4vaiaadkfacaWGibaaamaabmaabaGaaC4qamaaDaaaleaacaWG sbGaamisaiaad2eaaeaacaWGdbaaaaGccaGLOaGaayzkaaWaaSbaaS qaaiaadQgaaeqaaaaakiaawIcacaGLPaaaaaGaayjkaiaawMcaaaWc baGaamOAaiabg2da9iaaigdaaeaacaWGobaaniabggHiLdaaaOGaay jkaiaawMcaaiaahwhadaqadaqaaiabeM8a3bGaayjkaiaawMcaaiab g2da9iaahAgadaqadaqaaiabeM8a3bGaayjkaiaawMcaaaaa@03F3@
Frequency Response Analysis with WR3, WR4 and WRH (SYNC)
Parameters PARAM,WR3, PARAM,WR4 and PARAM,WRH can be used to avoid frequency dependent calculation of the rotor damping and circulation terms in systems with multiple rotors. The rotor speeds can be calculated as a linear function of the reference rotor spin rate (see description of terms below). The reference rotor spin rate values in the circulation damping terms are replaced with the values of the parameters as shown in Equation 4. PARAM,GYROAVG should be set to -1 to be able to bypass frequency dependent look-up and use the WR3, WR4, and WRH values.(4) − Ω ref 2 M−i ∑ j=1 N β j C RG j +i Ω ref C S + α s1 M S + α s2 K S + C SH + 1+iG K S +i C SM +i C SHM + ∑ j=1 N K R j +i Ω ref GR WR3 K R j +i Ω ref 1 WR4 C RM j +i Ω ref 1 WRH C RHM j +i Ω ref α j C RG j +i Ω ref α R1 M R + α R2 K R + C R + C RH j + α j + Ω ref β j C R C j + C RH C j + α R1 M R C + α R2 K R C j + GR WR3 K R C j + 1 WRH C RHM C j + 1 WR4 C RM C j u Ω ref =f Ω ref MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaadaqadaabaeqabaGaeyOeI0IaeuyQdC 1aa0baaSqaaiaadkhacaWGLbGaamOzaaqaaiaaikdaaaGcdaqadaqa aiaah2eacqGHsislcaWGPbWaaabCaeaacqaHYoGydaWgaaWcbaGaam OAaaqabaGcdaqadaqaaiaahoeadaWgaaWcbaGaamOuaiaadEeaaeqa aaGccaGLOaGaayzkaaWaaSbaaSqaaiaadQgaaeqaaaqaaiaadQgacq GH9aqpcaaIXaaabaGaamOtaaqdcqGHris5aaGccaGLOaGaayzkaaGa ey4kaSIaamyAaiabfM6axnaaBaaaleaacaWGYbGaamyzaiaadAgaae qaaOWaaeWaaeaacaWHdbWaaSbaaSqaaiaadofaaeqaaOGaey4kaSIa eqySde2aaSbaaSqaaiaadohacaaIXaaabeaakiaah2eadaWgaaWcba Gaam4uaaqabaGccqGHRaWkcqaHXoqydaWgaaWcbaGaam4Caiaaikda aeqaaOGaaC4samaaBaaaleaacaWGtbaabeaakiabgUcaRiaahoeada WgaaWcbaGaam4uaiaadIeaaeqaaaGccaGLOaGaayzkaaGaey4kaSYa aeWaaeaacaaIXaGaey4kaSIaamyAaiaadEeaaiaawIcacaGLPaaaca WHlbWaaSbaaSqaaiaadofaaeqaaOGaey4kaSIaamyAaiaahoeadaWg aaWcbaGaam4uaiaad2eaaeqaaOGaey4kaSIaamyAaiaahoeadaWgaa WcbaGaam4uaiaadIeacaWGnbaabeaaaOqaaiabgUcaRmaaqahabaWa aeWaaqaabeqaamaabmaabaGaaC4samaaBaaaleaacaWGsbaabeaaaO GaayjkaiaawMcaamaaBaaaleaacaWGQbaabeaakiabgUcaRiaadMga cqqHPoWvdaWgaaWcbaGaamOCaiaadwgacaWGMbaabeaakmaalaaaba Gaam4raiaadkfaaeaacaWGxbGaamOuaiaaiodaaaWaaeWaaeaacaWH lbWaaSbaaSqaaiaadkfaaeqaaaGccaGLOaGaayzkaaWaaSbaaSqaai aadQgaaeqaaOGaey4kaSIaamyAaiabfM6axnaaBaaaleaacaWGYbGa amyzaiaadAgaaeqaaOWaaSaaaeaacaaIXaaabaGaam4vaiaadkfaca aI0aaaamaabmaabaGaaC4qamaaBaaaleaacaWGsbGaamytaaqabaaa kiaawIcacaGLPaaadaWgaaWcbaGaamOAaaqabaGccqGHRaWkcaWGPb GaeuyQdC1aaSbaaSqaaiaadkhacaWGLbGaamOzaaqabaGcdaWcaaqa aiaaigdaaeaacaWGxbGaamOuaiaadIeaaaWaaeWaaeaacaWHdbWaaS baaSqaaiaadkfacaWGibGaamytaaqabaaakiaawIcacaGLPaaadaWg aaWcbaGaamOAaaqabaaakeaacqGHRaWkcaWGPbGaeuyQdC1aaSbaaS qaaiaadkhacaWGLbGaamOzaaqabaGccqaHXoqydaWgaaWcbaGaamOA aaqabaGcdaqadaqaaiaahoeadaWgaaWcbaGaamOuaiaadEeaaeqaaa GccaGLOaGaayzkaaWaaSbaaSqaaiaadQgaaeqaaOGaey4kaSIaamyA aiabfM6axnaaBaaaleaacaWGYbGaamyzaiaadAgaaeqaaOWaaeWaae aacqaHXoqydaWgaaWcbaGaamOuaiaaigdaaeqaaOGaaCytamaaBaaa leaacaWGsbaabeaakiabgUcaRiabeg7aHnaaBaaaleaacaWGsbGaaG OmaaqabaGccaWHlbWaaSbaaSqaaiaadkfaaeqaaOGaey4kaSIaaC4q amaaBaaaleaacaWGsbaabeaakiabgUcaRiaahoeadaWgaaWcbaGaam OuaiaadIeaaeqaaaGccaGLOaGaayzkaaWaaSbaaSqaaiaadQgaaeqa aaGcbaGaey4kaSYaaeWaaeaacqaHXoqydaWgaaWcbaGaamOAaaqaba GccqGHRaWkcqqHPoWvdaWgaaWcbaGaamOCaiaadwgacaWGMbaabeaa kiabek7aInaaBaaaleaacaWGQbaabeaaaOGaayjkaiaawMcaamaabm aaeaqabeaadaqadaqaaiaahoeadaqhaaWcbaGaamOuaaqaaiaadoea aaaakiaawIcacaGLPaaadaWgaaWcbaGaamOAaaqabaGccqGHRaWkda qadaqaaiaahoeadaqhaaWcbaGaamOuaiaadIeaaeaacaWGdbaaaaGc caGLOaGaayzkaaWaaSbaaSqaaiaadQgaaeqaaOGaey4kaSYaaeWaae aacqaHXoqydaWgaaWcbaGaamOuaiaaigdaaeqaaOGaaCytamaaDaaa leaacaWGsbaabaGaam4qaaaakiabgUcaRiabeg7aHnaaBaaaleaaca WGsbGaaGOmaaqabaGccaWHlbWaa0baaSqaaiaadkfaaeaacaWGdbaa aaGccaGLOaGaayzkaaWaaSbaaSqaaiaadQgaaeqaaaGcbaGaey4kaS YaaSaaaeaacaWGhbGaamOuaaqaaiaadEfacaWGsbGaaG4maaaadaqa daqaaiaahUeadaqhaaWcbaGaamOuaaqaaiaadoeaaaaakiaawIcaca GLPaaadaWgaaWcbaGaamOAaaqabaGccqGHRaWkdaWcaaqaaiaaigda aeaacaWGxbGaamOuaiaadIeaaaWaaeWaaeaacaWHdbWaa0baaSqaai aadkfacaWGibGaamytaaqaaiaadoeaaaaakiaawIcacaGLPaaadaWg aaWcbaGaamOAaaqabaGccqGHRaWkdaWcaaqaaiaaigdaaeaacaWGxb GaamOuaiaaisdaaaWaaeWaaeaacaWHdbWaa0baaSqaaiaadkfacaWG nbaabaGaam4qaaaaaOGaayjkaiaawMcaamaaBaaaleaacaWGQbaabe aaaaGccaGLOaGaayzkaaaaaiaawIcacaGLPaaaaSqaaiaadQgacqGH 9aqpcaaIXaaabaGaamOtaaqdcqGHris5aaaakiaawIcacaGLPaaaca WH1bWaaeWaaeaacqqHPoWvdaWgaaWcbaGaamOCaiaadwgacaWGMbaa beaaaOGaayjkaiaawMcaaiabg2da9iaahAgadaqadaqaaiabfM6axn aaBaaaleaacaWGYbGaamyzaiaadAgaaeqaaaGccaGLOaGaayzkaaaa aa@357F@
Complex Eigenvalue Analysis with WR3, WR4 and WRH (ASYNC)
The eigenvalues and critical speeds of a structure with rotating components can be determined using the rotor dynamics functionality in Complex Eigenvalue Analysis. In Asynchronous Analysis the critical speeds can also be determined by plotting the Campbell diagram for frequencies specified using the RSPEED Bulk Data Entry. The parameters PARAM,WR3, PARAM,WR4, and PARAM,WRH can be used to replace the values of WR3, WR4, and WRH in Equation 5.(5) − ω 2 M+iω C S + α s1 M S + α s2 K S + C SH + 1+iG K S +i C SM +i C SHM + ∑ j=1 N 1+iω GR WR3 K R j +iω 1 WR4 C RM j +iω 1 WRH C RHM j +iω α R1 M R + α R2 K R + C R + C RH j + Ω R j iω C RG j + C R C j + C RH C j + α R1 M R C + α R2 K R C j + GR WR3 K R C j + 1 WR4 C RM C j + 1 WRH C RHM C j u ω =0 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaadaqadaabaeqabaGaeyOeI0IaeqyYdC 3aaWbaaSqabeaacaaIYaaaaOGaaCytaiabgUcaRiaadMgacqaHjpWD daqadaqaaiaahoeadaWgaaWcbaGaam4uaaqabaGccqGHRaWkcqaHXo qydaWgaaWcbaGaam4CaiaaigdaaeqaaOGaaCytamaaBaaaleaacaWG tbaabeaakiabgUcaRiabeg7aHnaaBaaaleaacaWGZbGaaGOmaaqaba GccaWHlbWaaSbaaSqaaiaadofaaeqaaOGaey4kaSIaaC4qamaaBaaa leaacaWGtbGaamisaaqabaaakiaawIcacaGLPaaacqGHRaWkdaqada qaaiaaigdacqGHRaWkcaWGPbGaam4raaGaayjkaiaawMcaaiaahUea daWgaaWcbaGaam4uaaqabaGccqGHRaWkcaWGPbGaaC4qamaaBaaale aacaWGtbGaamytaaqabaGccqGHRaWkcaWGPbGaaC4qamaaBaaaleaa caWGtbGaamisaiaad2eaaeqaaaGcbaGaey4kaSYaaabCaeaadaqada abaeqabaWaaeWaaeaacaaIXaGaey4kaSIaamyAaiabeM8a3naabmaa baWaaSaaaeaacaWGhbGaamOuaaqaaiaadEfacaWGsbGaaG4maaaaai aawIcacaGLPaaaaiaawIcacaGLPaaadaqadaqaaiaahUeadaWgaaWc baGaamOuaaqabaaakiaawIcacaGLPaaadaWgaaWcbaGaamOAaaqaba GccqGHRaWkcaWGPbGaeqyYdC3aaeWaaeaadaWcaaqaaiaaigdaaeaa caWGxbGaamOuaiaaisdaaaaacaGLOaGaayzkaaWaaeWaaeaacaWHdb WaaSbaaSqaaiaadkfacaWGnbaabeaaaOGaayjkaiaawMcaamaaBaaa leaacaWGQbaabeaakiabgUcaRiaadMgacqaHjpWDdaqadaqaamaala aabaGaaGymaaqaaiaadEfacaWGsbGaamisaaaaaiaawIcacaGLPaaa daqadaqaaiaahoeadaWgaaWcbaGaamOuaiaadIeacaWGnbaabeaaaO GaayjkaiaawMcaamaaBaaaleaacaWGQbaabeaaaOqaaiabgUcaRiaa dMgacqaHjpWDdaqadaqaaiabeg7aHnaaBaaaleaacaWGsbGaaGymaa qabaGccaWHnbWaaSbaaSqaaiaadkfaaeqaaOGaey4kaSIaeqySde2a aSbaaSqaaiaadkfacaaIYaaabeaakiaahUeadaWgaaWcbaGaamOuaa qabaGccqGHRaWkcaWHdbWaaSbaaSqaaiaadkfaaeqaaOGaey4kaSIa aC4qamaaBaaaleaacaWGsbGaamisaaqabaaakiaawIcacaGLPaaada WgaaWcbaGaamOAaaqabaaakeaacqGHRaWkdaqadaqaaiabfM6axnaa BaaaleaacaWGsbaabeaaaOGaayjkaiaawMcaamaaBaaaleaacaWGQb aabeaakmaabmaaeaqabeaacaWGPbGaeqyYdC3aaeWaaeaacaWHdbWa aSbaaSqaaiaadkfacaWGhbaabeaaaOGaayjkaiaawMcaamaaBaaale aacaWGQbaabeaakiabgUcaRmaabmaabaGaaC4qamaaDaaaleaacaWG sbaabaGaam4qaaaaaOGaayjkaiaawMcaamaaBaaaleaacaWGQbaabe aakiabgUcaRmaabmaabaGaaC4qamaaDaaaleaacaWGsbGaamisaaqa aiaadoeaaaaakiaawIcacaGLPaaadaWgaaWcbaGaamOAaaqabaGccq GHRaWkdaqadaqaaiabeg7aHnaaBaaaleaacaWGsbGaaGymaaqabaGc caWHnbWaa0baaSqaaiaadkfaaeaacaWGdbaaaOGaey4kaSIaeqySde 2aaSbaaSqaaiaadkfacaaIYaaabeaakiaahUeadaqhaaWcbaGaamOu aaqaaiaadoeaaaaakiaawIcacaGLPaaadaWgaaWcbaGaamOAaaqaba aakeaacqGHRaWkdaWcaaqaaiaadEeacaWGsbaabaGaam4vaiaadkfa caaIZaaaamaabmaabaGaaC4samaaDaaaleaacaWGsbaabaGaam4qaa aaaOGaayjkaiaawMcaamaaBaaaleaacaWGQbaabeaakiabgUcaRmaa laaabaGaaGymaaqaaiaadEfacaWGsbGaaGinaaaadaqadaqaaiaaho eadaqhaaWcbaGaamOuaiaad2eaaeaacaWGdbaaaaGccaGLOaGaayzk aaWaaSbaaSqaaiaadQgaaeqaaOGaey4kaSYaaSaaaeaacaaIXaaaba Gaam4vaiaadkfacaWGibaaamaabmaabaGaaC4qamaaDaaaleaacaWG sbGaamisaiaad2eaaeaacaWGdbaaaaGccaGLOaGaayzkaaWaaSbaaS qaaiaadQgaaeqaaaaakiaawIcacaGLPaaaaaGaayjkaiaawMcaaaWc baGaamOAaiabg2da9iaaigdaaeaacaWGobaaniabggHiLdaaaOGaay jkaiaawMcaaiaahwhadaqadaqaaiabeM8a3bGaayjkaiaawMcaaiab g2da9iaaicdaaaa@0068@
Complex Eigenvalue Analysis with WR3, WR4 and WRH (SYNC)
Only the rotor speeds are required to perform the Synchronous Complex Eigenvalue Analysis as the whirl frequencies are equal to the reference rotor spin rates. Only the critical speeds are output as a result of this analysis. The parameters PARAM,WR3, PARAM,WR4, and PARAM,WRH can be used to replace the values of WR3, WR4, and WRH in Equation 6.(6) − Ω ref 2 M−i ∑ j=1 N β j C RG j +i Ω ref C S + α s1 M S + α s2 K S + C SH + 1+iG K S +i C SM +i C SHM + ∑ j=1 N K R j +i Ω ref GR WR3 K R j + 1 WR4 C RM j + 1 WRH C RHM j + α j C RG j + α R1 M R + α R2 K R + C R + C RH j + α j + Ω ref β j C R C j + C RH C j + α R1 M R C + α R2 K R C j + GR WR3 K R C j + 1 WRH C RHM C j + 1 WR4 C RM C j u Ω ref =0 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaadaqadaabaeqabaGaeyOeI0IaeuyQdC 1aa0baaSqaaiaadkhacaWGLbGaamOzaaqaaiaaikdaaaGcdaqadaqa aiaah2eacqGHsislcaWGPbWaaabCaeaacqaHYoGydaWgaaWcbaGaam OAaaqabaGcdaqadaqaaiaahoeadaWgaaWcbaGaamOuaiaadEeaaeqa aaGccaGLOaGaayzkaaWaaSbaaSqaaiaadQgaaeqaaaqaaiaadQgacq GH9aqpcaaIXaaabaGaamOtaaqdcqGHris5aaGccaGLOaGaayzkaaGa ey4kaSIaamyAaiabfM6axnaaBaaaleaacaWGYbGaamyzaiaadAgaae qaaOWaaeWaaeaacaWHdbWaaSbaaSqaaiaadofaaeqaaOGaey4kaSIa eqySde2aaSbaaSqaaiaadohacaaIXaaabeaakiaah2eadaWgaaWcba Gaam4uaaqabaGccqGHRaWkcqaHXoqydaWgaaWcbaGaam4Caiaaikda aeqaaOGaaC4samaaBaaaleaacaWGtbaabeaakiabgUcaRiaahoeada WgaaWcbaGaam4uaiaadIeaaeqaaaGccaGLOaGaayzkaaGaey4kaSYa aeWaaeaacaaIXaGaey4kaSIaamyAaiaadEeaaiaawIcacaGLPaaaca WHlbWaaSbaaSqaaiaadofaaeqaaOGaey4kaSIaamyAaiaahoeadaWg aaWcbaGaam4uaiaad2eaaeqaaOGaey4kaSIaamyAaiaahoeadaWgaa WcbaGaam4uaiaadIeacaWGnbaabeaaaOqaaiabgUcaRmaaqahabaWa aeWaaqaabeqaamaabmaabaGaaC4samaaBaaaleaacaWGsbaabeaaaO GaayjkaiaawMcaamaaBaaaleaacaWGQbaabeaakiabgUcaRiaadMga cqqHPoWvdaWgaaWcbaGaamOCaiaadwgacaWGMbaabeaakmaabmaaea qabeaadaWcaaqaaiaadEeacaWGsbaabaGaam4vaiaadkfacaaIZaaa amaabmaabaGaaC4samaaBaaaleaacaWGsbaabeaaaOGaayjkaiaawM caamaaBaaaleaacaWGQbaabeaakiabgUcaRmaalaaabaGaaGymaaqa aiaadEfacaWGsbGaaGinaaaadaqadaqaaiaahoeadaWgaaWcbaGaam Ouaiaad2eaaeqaaaGccaGLOaGaayzkaaWaaSbaaSqaaiaadQgaaeqa aOGaey4kaSYaaSaaaeaacaaIXaaabaGaam4vaiaadkfacaWGibaaam aabmaabaGaaC4qamaaBaaaleaacaWGsbGaamisaiaad2eaaeqaaaGc caGLOaGaayzkaaWaaSbaaSqaaiaadQgaaeqaaOGaey4kaSIaeqySde 2aaSbaaSqaaiaadQgaaeqaaOWaaeWaaeaacaWHdbWaaSbaaSqaaiaa dkfacaWGhbaabeaaaOGaayjkaiaawMcaamaaBaaaleaacaWGQbaabe aaaOqaaiabgUcaRmaabmaabaGaeqySde2aaSbaaSqaaiaadkfacaaI Xaaabeaakiaah2eadaWgaaWcbaGaamOuaaqabaGccqGHRaWkcqaHXo qydaWgaaWcbaGaamOuaiaaikdaaeqaaOGaaC4samaaBaaaleaacaWG sbaabeaakiabgUcaRiaahoeadaWgaaWcbaGaamOuaaqabaGccqGHRa WkcaWHdbWaaSbaaSqaaiaadkfacaWGibaabeaaaOGaayjkaiaawMca amaaBaaaleaacaWGQbaabeaaaaGccaGLOaGaayzkaaaabaGaey4kaS YaaeWaaeaacqaHXoqydaWgaaWcbaGaamOAaaqabaGccqGHRaWkcqqH PoWvdaWgaaWcbaGaamOCaiaadwgacaWGMbaabeaakiabek7aInaaBa aaleaacaWGQbaabeaaaOGaayjkaiaawMcaamaabmaaeaqabeaadaqa daqaaiaahoeadaqhaaWcbaGaamOuaaqaaiaadoeaaaaakiaawIcaca GLPaaadaWgaaWcbaGaamOAaaqabaGccqGHRaWkdaqadaqaaiaahoea daqhaaWcbaGaamOuaiaadIeaaeaacaWGdbaaaaGccaGLOaGaayzkaa WaaSbaaSqaaiaadQgaaeqaaOGaey4kaSYaaeWaaeaacqaHXoqydaWg aaWcbaGaamOuaiaaigdaaeqaaOGaaCytamaaDaaaleaacaWGsbaaba Gaam4qaaaakiabgUcaRiabeg7aHnaaBaaaleaacaWGsbGaaGOmaaqa baGccaWHlbWaa0baaSqaaiaadkfaaeaacaWGdbaaaaGccaGLOaGaay zkaaWaaSbaaSqaaiaadQgaaeqaaaGcbaGaey4kaSYaaSaaaeaacaWG hbGaamOuaaqaaiaadEfacaWGsbGaaG4maaaadaqadaqaaiaahUeada qhaaWcbaGaamOuaaqaaiaadoeaaaaakiaawIcacaGLPaaadaWgaaWc baGaamOAaaqabaGccqGHRaWkdaWcaaqaaiaaigdaaeaacaWGxbGaam OuaiaadIeaaaWaaeWaaeaacaWHdbWaa0baaSqaaiaadkfacaWGibGa amytaaqaaiaadoeaaaaakiaawIcacaGLPaaadaWgaaWcbaGaamOAaa qabaGccqGHRaWkdaWcaaqaaiaaigdaaeaacaWGxbGaamOuaiaaisda aaWaaeWaaeaacaWHdbWaa0baaSqaaiaadkfacaWGnbaabaGaam4qaa aaaOGaayjkaiaawMcaamaaBaaaleaacaWGQbaabeaaaaGccaGLOaGa ayzkaaaaaiaawIcacaGLPaaaaSqaaiaadQgacqGH9aqpcaaIXaaaba GaamOtaaqdcqGHris5aaaakiaawIcacaGLPaaacaWH1bWaaeWaaeaa cqqHPoWvdaWgaaWcbaGaamOCaiaadwgacaWGMbaabeaaaOGaayjkai aawMcaaiabg2da9iaaicdaaaa@1AC8@
Static
For Static Analysis, the following moment term is added to the load vector at each rotor grid.(7) f = − ∑ j = 1 N Ω j ( C R G ) j ω → MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaacaWHMbGaeyypa0JaeyOeI0YaaabCae aacqqHPoWvdaWgaaWcbaGaamOAaaqabaaabaGaamOAaiabg2da9iaa igdaaeaacaWGobaaniabggHiLdGcdaqadaqaaiaahoeadaWgaaWcba GaamOuaiaadEeaaeqaaaGccaGLOaGaayzkaaWaaSbaaSqaaiaadQga aeqaaOWaa8HaaeaacqaHjpWDaiaawEniaaaa@45DD@
Linear and Small Displacement Nonlinear Direct Transient Analysis
The rotor speeds ( Ω MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaiabfM6axbaa@3779@ ) are time-dependent in Transient Rotor Dynamics. The displacement equation (with WR3, WR4, and WRH) is:(8) M u ¨ (t)+ u ˙ (t) C S + α s1 M S + α s2 K S + C SH + G W3 K S + 1 W4 C SM + 1 WH C SHM + ∑ j=1 N α R1 M R + α R2 K R j + C R j + C RH j + G R j WR3 K R j + 1 WR4 C RM j + 1 WRH C RHM j + Ω j (t) C RG j +u(t) K S + ∑ j=1 N K R j + Ω j (t) C R C j + α R1 M R C + α R2 K R C j + C RH C j + G R j WR3 K R C j + 1 WR4 C RM C j + 1 WRH C RHM C j + Ω ˙ j (t) K R T j =f(t) MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOabaeqabaGaaCytai qadwhagaWaaiaacIcacaWG0bGaaiykaiabgUcaRiqadwhagaGaaiaa cIcacaWG0bGaaiykamaabmaaeaqabeaacaWHdbWaaSbaaSqaaiaado faaeqaaOGaey4kaSIaeqySde2aaSbaaSqaaiaadohacaaIXaaabeaa kiaah2eadaWgaaWcbaGaam4uaaqabaGccqGHRaWkcqaHXoqydaWgaa WcbaGaam4CaiaaikdaaeqaaOGaaC4samaaBaaaleaacaWGtbaabeaa kiabgUcaRiaahoeadaWgaaWcbaGaam4uaiaadIeaaeqaaOGaey4kaS YaaeWaaeaadaWcaaqaaiaadEeaaeaacaWGxbGaaG4maaaaaiaawIca caGLPaaacaWHlbWaaSbaaSqaaiaadofaaeqaaOGaey4kaSYaaeWaae aadaWcaaqaaiaaigdaaeaacaWGxbGaaGinaaaaaiaawIcacaGLPaaa caWHdbWaaSbaaSqaaiaadofacaWGnbaabeaakiabgUcaRmaabmaaba WaaSaaaeaacaaIXaaabaGaam4vaiaadIeaaaaacaGLOaGaayzkaaGa aC4qamaaBaaaleaacaWGtbGaamisaiaad2eaaeqaaaGcbaGaey4kaS YaaabCaeaadaqadaabaeqabaWaaeWaaeaacqaHXoqydaWgaaWcbaGa amOuaiaaigdaaeqaaOGaaCytamaaBaaaleaacaWGsbaabeaakiabgU caRiabeg7aHnaaBaaaleaacaWGsbGaaGOmaaqabaGccaWHlbWaaSba aSqaaiaadkfaaeqaaaGccaGLOaGaayzkaaWaaSbaaSqaaiaadQgaae qaaOGaey4kaSYaaeWaaeaacaWHdbWaaSbaaSqaaiaadkfaaeqaaaGc caGLOaGaayzkaaWaaSbaaSqaaiaadQgaaeqaaOGaey4kaSYaaeWaae aacaWHdbWaaSbaaSqaaiaadkfacaWGibaabeaaaOGaayjkaiaawMca amaaBaaaleaacaWGQbaabeaakiabgUcaRmaabmaabaWaaSaaaeaaca WGhbGaamOuamaaBaaaleaacaWGQbaabeaaaOqaaiaadEfacaWGsbGa aG4maaaaaiaawIcacaGLPaaadaqadaqaaiaahUeadaWgaaWcbaGaam OuaaqabaaakiaawIcacaGLPaaadaWgaaWcbaGaamOAaaqabaaakeaa cqGHRaWkdaqadaqaamaalaaabaGaaGymaaqaaiaadEfacaWGsbGaaG inaaaaaiaawIcacaGLPaaadaqadaqaaiaahoeadaWgaaWcbaGaamOu aiaad2eaaeqaaaGccaGLOaGaayzkaaWaaSbaaSqaaiaadQgaaeqaaO Gaey4kaSYaaeWaaeaadaWcaaqaaiaaigdaaeaacaWGxbGaamOuaiaa dIeaaaaacaGLOaGaayzkaaWaaeWaaeaacaWHdbWaaSbaaSqaaiaadk facaWGibGaamytaaqabaaakiaawIcacaGLPaaadaWgaaWcbaGaamOA aaqabaGccqGHRaWkcqqHPoWvdaWgaaWcbaGaamOAaaqabaGccaGGOa GaamiDaiaacMcadaqadaqaaiaahoeadaWgaaWcbaGaamOuaiaadEea aeqaaaGccaGLOaGaayzkaaWaaSbaaSqaaiaadQgaaeqaaaaakiaawI cacaGLPaaaaSqaaiaadQgacqGH9aqpcaaIXaaabaGaamOtaaqdcqGH ris5aaaakiaawIcacaGLPaaaaeaacqGHRaWkcaWG1bGaaiikaiaads hacaGGPaWaaeWaaeaacaWHlbWaaSbaaSqaaiaadofaaeqaaOGaey4k aSYaaabCaeaadaqadaqaamaabmaabaGaaC4samaaBaaaleaacaWGsb aabeaaaOGaayjkaiaawMcaamaaBaaaleaacaWGQbaabeaakiabgUca RiabfM6axnaaBaaaleaacaWGQbaabeaakiaacIcacaWG0bGaaiykam aabmaaeaqabeaadaqadaqaaiaahoeadaqhaaWcbaGaamOuaaqaaiaa doeaaaaakiaawIcacaGLPaaadaWgaaWcbaGaamOAaaqabaGccqGHRa Wkdaqadaqaaiabeg7aHnaaBaaaleaacaWGsbGaaGymaaqabaGccaWH nbWaa0baaSqaaiaadkfaaeaacaWGdbaaaOGaey4kaSIaeqySde2aaS baaSqaaiaadkfacaaIYaaabeaakiaahUeadaqhaaWcbaGaamOuaaqa aiaadoeaaaaakiaawIcacaGLPaaadaWgaaWcbaGaamOAaaqabaGccq GHRaWkdaqadaqaaiaahoeadaqhaaWcbaGaamOuaiaadIeaaeaacaWG dbaaaaGccaGLOaGaayzkaaWaaSbaaSqaaiaadQgaaeqaaaGcbaGaey 4kaSYaaeWaaeaadaWcaaqaaiaadEeacaWGsbWaaSbaaSqaaiaadQga aeqaaaGcbaGaam4vaiaadkfacaaIZaaaaaGaayjkaiaawMcaamaabm aabaGaaC4samaaDaaaleaacaWGsbaabaGaam4qaaaaaOGaayjkaiaa wMcaamaaBaaaleaacaWGQbaabeaakiabgUcaRmaabmaabaWaaSaaae aacaaIXaaabaGaam4vaiaadkfacaaI0aaaaaGaayjkaiaawMcaamaa bmaabaGaaC4qamaaDaaaleaacaWGsbGaamytaaqaaiaadoeaaaaaki aawIcacaGLPaaadaWgaaWcbaGaamOAaaqabaGccqGHRaWkdaqadaqa amaalaaabaGaaGymaaqaaiaadEfacaWGsbGaamisaaaaaiaawIcaca GLPaaadaqadaqaaiaahoeadaqhaaWcbaGaamOuaiaadIeacaWGnbaa baGaam4qaaaaaOGaayjkaiaawMcaamaaBaaaleaacaWGQbaabeaaaa GccaGLOaGaayzkaaGaey4kaSIafuyQdCLbaiaadaWgaaWcbaGaamOA aaqabaGccaGGOaGaamiDaiaacMcadaqadaqaaiaahUeadaqhaaWcba GaamOuaaqaaiaadsfaaaaakiaawIcacaGLPaaadaWgaaWcbaGaamOA aaqabaaakiaawIcacaGLPaaaaSqaaiaadQgacqGH9aqpcaaIXaaaba GaamOtaaqdcqGHris5aaGccaGLOaGaayzkaaGaeyypa0JaaCOzaiaa cIcacaWG0bGaaiykaaaaaa@26A9@
Where,
Ω r e f
Reference rotor spin rate
Ω R j ( Ω r e f )
Spin rate of rotor " j " as a function of the reference rotor spin rate.
Ω R j ( Ω r e f )
Determined for each excitation frequency or it can be calculated as a linear function of the reference rotor spin rate:(9) Ω R j ( Ω r e f ) = α j + β j Ω r e f
Where, a j and β j are scaling factors calculated from the relative spin rates defined in the RSPINR Bulk Data Entry.
[ M ]
Structural mass
α j
Viscous damping of the support
C R
Rotor viscous damping
C R H
Rotor hybrid viscous damping
M R
Rotor mass
K R
Rotor stiffness
C R M
Rotor material damping
C R H
Rotor hybrid material damping
C R C
Circulation, due to rotor viscous damping
C R H C
Circulation due to rotor hybrid viscous damping
M R C
Circulation, due to rotor mass
K R C
Circulation, due to rotor structural stiffness
C R M C
Circulation, due to rotor material damping
C R H C
Circulation, due to rotor hybrid material damping
K S
Stiffness of the support
M S MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaacaWHnbWaaSbaaSqaaiaadofaaeqaaa aa@3392@
Mass of the support.
C S M
Material damping of the support
C SH MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaacaWHdbWaaSbaaSqaaiaadofacaWGib aabeaaaaa@3454@
Hybrid viscous damping of the support.
C SHM MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaiaahoeadaWgaa WcbaGaam4uaiaadIeacaWGnbaabeaaaaa@3957@
Hybrid material damping of the support.
N
Number of rotors in the model
u ( ω )
Displacement as a function of frequency
u ( Ω r e f )
Displacement as a function of reference rotor spin rate
f ( ω )
External excitation as a function of frequency
f ( Ω r e f )
Unbalanced load as a function of reference rotor spin rate (via DAREA or UNBALNC Bulk Data Entries)
G
Structural damping value of the support defined using PARAM,G
G R
Structural damping value of the rotor defined using PARAM,G
ω → MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaadaWhcaqaaiabeM8a3bGaay51Gaaaaa@353B@
Angular velocity vector obtained from a pertinent RFORCE Bulk Data Entry
WR3, WR4, and WRH are defined via the parameters PARAM, WR3, PARAM, WR4, and PARAM, WRH. They may also be rotor dependent and specified on RSPINR and RSPINT Bulk Data Entries. These parameters allow you to bypass frequency-dependent looping by specifying the equivalent “average” excitation frequencies when PARAM, GYROAVG, -1 is specified.
The general form of a circulation damping term is given as:(10) D C = 1 2 ( T D + D T )
Where,
D
Regular damping matrix
T
Skew-symmetric rotation matrix defined as follows in the rotor coordinate system
(11) T = [ 0 − 1 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 − 1 0 0 0 0 1 0 0 0 0 0 0 0 0 ]
This 6x6 T matrix is repeated for each grid along the rotation axis of the rotor. The individual T matrices are added in the diagonal of the global skew-symmetric matrix.
C R G
Gyroscopic matrix defined in a rotor coordinate system as:(12) C R G = [ 0   0   0   0   0   0 0   0   0   0   0     0 0   0   0   0   0     0 0   0   0   0   0     0 0   0   0   0   0     I 33 0   0   0   0     − I 33     0 ]
Model Guidelines
1D Rotor Model
Rotor shafts modeled with 1D elements like CBEAM, CBAR, or CBUSH on the ROTORG entry. CONM1 or CONM2 entries should be used to define the mass and inertia of the rotors. Grid points are necessary for the definition of mass and inertia via CONM1 or CONM2. All grid points that belong to 1D rotors should be listed in the ROTORG entries and only grids listed in the ROTORG entries are included in the calculation of gyroscopic terms. The Ixx fields on the CONM2 entry should contain meaningful values as only the inertia about the local X, Y, or Z axes plays a role in the gyroscopic forces (Supported Solution Sequences). If CONM1 entries are used, the Mxy mass values should be specified such that the moments of inertia about the local X, Y, or Z axes are meaningful.
3D Rotor Model
Rotor shafts can also be modeled in 3D via the ROTOR Bulk Data Entry.
Supported elements:
  • 0D elements : CONM1, CONM2
  • 1D elements : CBEAM, CBAR
  • 3D elements : CHEXA, CPENTA, CTETRA, CPYRA
All elements that belong to 3D rotors should be listed in the ROTOR entries and only elements listed in the ROTOR entries are included in the calculation of gyroscopic terms for 3D rotors.
Detached Rotor Model
For both 1D and 3D rotors, the rotor should be detached from the rest of the structure. Only rigid elements (RBEi) can be used to attach rotors to the ground or to flexible bearings. If any connection exists between the rotor and other parts of the structure using elements other than RBEi, then an error is issued.
Symmetric Rotor in a Fixed Reference Frame
Rotor Dynamics Analysis in OptiStruct is performed based on assumption that the rotor is symmetric. Therefore, the rotor model is required to be symmetric about the rotation axis. The implementation is based on equations of motion formulated in a fixed reference frame. Asymmetric rotors in a rotating reference frame is planned to be implemented in future versions of OptiStruct.
Rotor-axis Guidelines
The axis of rotation of the rotor is defined by the Grid A and Grid B specified in RSPINR/RSPINT Bulk Data Entries.
  1. These grids are permitted to have a user-defined input coordinate system. As the rotor axis is dependent on the input coordinate system, this definition would change the direction of the rotor axis.
  2. These grids can also have a user-defined output coordinate system. The output coordinate system does not affect the direction of the rotor axis.
For 1D rotors defined via ROTORG, all other grids that define the rotor in the ROTORG card must lie on the line defined by the grids A and B, else this would lead to an error message.
Figure 3. 1D rotors - grid points definition. (a) outside line AB; (b) on line AB
Multiple Rotors
During Synchronous Analysis, the calculations are performed with respect to the reference rotor. In Synchronous Frequency Response Analysis, the reference rotor is rotating at the frequency of the unbalanced load and in Synchronous Complex Eigenvalue Analysis, the reference rotor is rotating at the whirl frequency of the system. The interpretation of results in a multiple rotor system should always be done with respect to the reference rotor. Any deduction of results from the behavior of rotors other than the reference rotor will be inaccurate and can lead to incorrect results. If the behavior of a rotor other than the reference rotor is to be studied, a different analysis should be run with the rotor of interest as the reference rotor.
Multiple rotors can be included in a single model in OptiStruct. For 1D rotors, each rotor is defined using a ROTORG card and its properties can be specified using RSPINR/RSPINT entries. For 3D rotors, each rotor is defined using a ROTOR card. In case of Transient Analysis, there is no reference and each of the rotors spin independent of the other. In other analyses, one of the rotors must be identified as a ‘reference’ in the RGYRO Bulk Entry. These rotors may be:
Co-axial
Rotors share the same axes of rotation
Multi-axial
Rotors have different axes of rotation
Campbell Diagram
The critical speeds of a rotating structure should be calculated and the design parameters can then be altered if necessary to restrict the operating speeds of the structure from attaining those resonant speeds.
The structure may undergo excessive amplitude and phase changes if its operating speeds reach critical speeds. The calculation of critical speeds in OptiStruct can be undertaken in two ways:
  1. Synchronous Complex Eigenvalue Analysis
    The RGYRO=SYNC option in Complex Eigenvalue Analysis can be used to determine the exact critical speeds of the rotating structure. During a synchronous analysis, the rotor speed is equal to the whirl frequency of the structure, which by definition, are the critical speeds of the structure that should be avoided during its operation.
    Figure 4. Campbell Diagram to Calculate the Critical Speeds
  2. Asynchronous Complex Eigenvalue Analysis
    The RGYRO=ASYNC option and the RSPEED Bulk Data Entry in Complex Eigenvalue Analysis can be used to determine the whirl frequencies (backward whirl and forward whirl) of the structure. These Whirl frequencies can be calculated for a sequence of rotor spin rates. Forward Whirl and Backward Whirl frequencies can then be plotted against the range of rotor spin rates (Figure 4). The critical speeds can be calculated by superimposing the "Rotor Spin Rate = Whirl Frequencies" line on the plot. The points of intersection are the critical speeds.
    Note: The rotor speeds specified on the RSPEED entry should be input with sufficiently fine resolution to be able to capture the critical speeds. If the specified rotor speeds are too far apart, the critical speeds may be missed.
Campbell Diagram in HyperGraph 2D
The procedure to create the Campbell Diagram in HyperGraph 2D is:
  1. The rotor speed versus frequency plots are generated from the .out file in HyperGraph 2D. An example is shown below with X request as Mode 1.
    Example of Control options in HyperGraph 2D for Plotting the Campbell Diagram.
    X Type
    Subcase: 1 Campbell Summary
    X Request
    Mode 1
    X Component
    Rotor Speed
    Y Type
    Y Request
    All Required Modes
    Y Component
    Frequency
    Figure 5. Control Options in HyperGraph 2D
  2. From the Plot Browser, all the required curves are chosen. Right-click Multiple Curves Math, then select Campbell Diagram.
    The Campbell Diagram dialog opens.
    Figure 6. Plot Campbell Diagram in HyperGraph 2D
  3. In the Campbell Diagram dialog, set the options in Figure 6 and click OK.
    Figure 7. Campbell Diagram in HyperGraph 2D
Rotor Superelements
Rotors in frequency response and complex eigenvalue solutions can be replaced using superelements.
Superelements can be attached to the grids that define the rotor in the ROTORG Bulk Data Entry. Craig-Bampton Nodal Formulation (CBN) or Guyan Reduction (GUYAN) can be specified on the METHOD field in the CMSMETH Bulk Data Entry to generate the superelements. The superelement replaces the beam elements used to model the rotor. The ASET grid points should correspond to the GRIDi points specified on the ROTORG Bulk Data Entry. The interface grid points of the superelement used to model the rotor should be exactly the same grid points defined on the ROTORG Bulk Data Entry. The General Modal Formulation (GM method) cannot be used to generate superelements for rotor dynamics.
Note: The Inertia (I66) and equivalent mass information pertaining to the Rotor superelement at the ASET connection points is printed to the .out file. This inertia information can subsequently be utilized to aid in replacing the rotor superelement with equivalent CONM2 concentrated mass elements.
Output
The rotor speed, eigenvales (real and imaginary), frequency, damping and whirl details are printed for each mode, under Campbell diagram Summary in the .out file. An example is shown below.
Subcase: 1
                           Campbell Diagram Summary
 Mode #: 1
 Step  Rotor speed   Eigenvalue  Eigenvalue     Frequency    Damping     Whirl
           (RPM)         (Re)        (Im)          (Hz)
   1    0.000E+00  -1.92148E-01 -3.81017E+02    6.064E+01    1.009E-03  LINEAR
   2    2.000E+02  -1.92108E-01 -3.81011E+02    6.064E+01    1.008E-03  BACKWARD
   3    4.000E+02  -1.91987E-01  3.80993E+02    6.064E+01    1.008E-03  BACKWARD
   4    6.000E+02  -1.91788E-01 -3.80964E+02    6.063E+01    1.007E-03  BACKWARD
   5    8.000E+02  -1.91513E-01  3.80924E+02    6.063E+01    1.006E-03  BACKWARD
   6    1.000E+03  -1.91163E-01  3.80873E+02    6.062E+01    1.004E-03  BACKWARD
   7    1.200E+03  -1.90742E-01  3.80810E+02    6.061E+01    1.002E-03  BACKWARD
 Mode #: 2
   1    0.000E+00  -1.92148E-01  3.81017E+02    6.064E+01    1.009E-03  LINEAR
   2    2.000E+02  -1.92108E-01  3.81011E+02    6.064E+01    1.008E-03  BACKWARD
   3    4.000E+02  -1.91987E-01 -3.80993E+02    6.064E+01    1.008E-03  BACKWARD
   4    6.000E+02  -1.91788E-01  3.80964E+02    6.063E+01    1.007E-03  BACKWARD
   5    8.000E+02  -1.91513E-01 -3.80924E+02    6.063E+01    1.006E-03  BACKWARD
   6    1.000E+03  -1.91163E-01 -3.80873E+02    6.062E+01    1.004E-03  BACKWARD
   7    1.200E+03  -1.90742E-01 -3.80810E+02    6.061E+01    1.002E-03  BACKWARD
Note:
  • In rare cases, when the job is run in different machines, a given model might show flip in the sign of imaginary eigenvalues between a pair of modes. This is due to numerical differences while ordering the modes.
  • As the roots are complex conjugates, if the sign changes for a particular step (that is, rotor speed) in a mode, then the same step will have opposite sign in a consecutive mode.
