Create a rigid imaginary rigid part between arbitrary faces/spots.
        Only bonded contact is supported.
                On the Project Tree, click
                    on the Connections workbench
                On the Connections workbench, select .
                In the Virtual connector dialog, use the radio buttons to
                    specify whether to apply connector to a Face or
                        Spot.
- Optional:
                If applying to Spots, you can create new spots by clicking Create
                        new spot.
                On the modeling window, click to select specific parts on the model.
Your selections will appear in the Virtual
                        connector dialog.
                Click OK.
The general connector will appear in the Connections branch. If
                    selected, it will be visually represented in the modeling window.
