Imported Bushing
Defines directional stiffness between two parts that lie within specified diameter from the bushing center via importing a .csv file.
Imported Bushing CSV File Format
CSV file format for importing bushings.
- X, Y and Z – Numeric values. Spatial location of bushing center.
 - Diameter – Numeric value. Points will be mapped on the parts within the specified diameter from the bushing center.
 - Stiffness Linear/angular X, Y, and Z – Numerical values.
 - Coordinate system - Coordinate system name. Name of the bushing coordinate
                        system to resolve the stiffness. Global coordinate system will be used if
                        the coordinate system fields are empty in the
                            .csv.Note: Spatial location of bushing center will still be in global coordinate system.
