Rivet
Connect multiple part with rivets of a given diameter.
- On the Project Tree, click on the Connections workbench
                On the Connections workbench, select
 > Rivet.
                Use one of the following methods to create the Rivet:
Method Process Pick rivet location - Select the Stand alone rivets radio button.
 - Specify Rivet diameter.
 - In the modeling window, select locations on the model.
Import rivets from CSV - Select the Import rivents from CSV radio button.
 - Click Import.
 - Browse to the desired CSV file.
 - Click Open
                Click OK.
                The connector will appear in the Connections branch. If selected, it will be visually represented in the modeling window.
