Connect faces or spots to a ground support.
        Three ground supports are available:
                - Ball hinge: Ball hinge can rotate in any direction about the remote point.
                - Rotating Hinge: Rotating hinge can only rotate about the hinge axis. The axis is
                    defined by the remote point coordinates and a vector.
                - Rotating-slide hinge: Rotating-sliding hinge can rotate about the hinge axis and
                    also slide along the axis. The axis is defined by the remote point coordinates
                    and a vector.
Virtual connectors create perfectly
                            rigid boundaries, stresses along the boundary faces can have local
                            concentrations.
                On the Project Tree, click
                    on the Connections workbench
                On the Connections workbench, select .
                Create one of the following types of supports:
| Type |
Process |
                        | Ball hinge |
                                - In the Virtual connector dialog, select the
                                        Ball hinge radio button.
                                - Under Apply to, use the radio buttons to specify whether to
                                    apply connector to a Face or
                                        Spot.
                                - If applying to Spots, you can create new spots by clicking
                                        Create new spots.
                                - In the modeling window, click to select
                                    specific parts on the model.
                                - The
                        remote point coordinates are set in COG by default. To edit the coordinates,
                        uncheck the Set in COG checkbox and specify values
                        for the X, Y, and Z fields.
                        | Rotating hinge |
                                        Rotating hinge radio button.
                                        Spot.
                                        Create new spots.
                                - The
                                - Under Hinge axis, specify values for the X, Y, and Z
                                    fields.
                        | Rotating-slide hinge |
                                        Rotating-slide hinge radio
                                    button.
                                        Spot.
                                        Create new spots.
                                - The
                                    fields.
                Click OK.
The connector appears in the Connections branch. If selected, it is
                    visually represented in the modeling window.
