Create a virtual cable/rod with finite or infinite stiffness between two different
        parts or between a single part and ground. Virtual cable/rod is applied on
        spots.
                In the Project Tree, click the Connections workbench.
                On the Connections workbench, select .
                In the dialog, use the radio buttons to select cable or rod type.
                Apply to spots. You can also create new spots by clicking Create new
                        spot.
                If Type is set to Cable or Rod,
                    use the radio buttons for End1 and
                        End2 and select the spots for each end.
                If Type is set to Grounded cable or Grounded
                        rod, set the radio button to End 1 and
                    select a spot. Switch to Ground and enter the coordinates
                    of the ground point.
                Set the stiffness of the cable/rod. Check that the Rigid option is set to
                        Infinite stiffness.
                Click Apply.
The virtual connector will appear in the Connections branch. If
                    selected, you will see vectors representing the connection in the modeling
                    window.
