Alignment Constraints
- On the Project Tree, open the Analysis Workbench.
                On the Analysis Workbench toolbar, click
 (Alignment).
                In the modeling window, click to select faces of
                    specific parts on the model.
                Note: Selected faces must be cylindrical. Your selections will appear in the Alignment dialog.
                Click OK.
                The alignment will appear in the Project Tree. If selected, it will be visually represented in the modeling window.
