In thermal analysis, simulate internal heat generation and internal heat absorption
        in volumes.
        A positive volume heat value indicates a heat source, and a negative volume heat
            value indicates a heat sink.
                In the Project Tree, click on a Thermal analysis branch to open the
                        Analysis Workbench.
                On the workbench toolbar, click the
(Volume heat) icon.
                The Volume heat dialog will open.
                On the modeling window, click to select specific parts on the model.
                Specify volume heat units and value.
                Click OK to create.
