Simulate the force of gravity as it affects your model.
        Only one gravity load can be applied to a model. Gravity load acts on all
            unsuppressed parts of the model.
                On the Project Tree, open
                    the Analysis Workbench.
                In the workbench toolbar, click the
 (Gravity load) icon.
                In the dialog, specify directional components of the load in the X, Y, and Z
                    fields.
                    Note: Enter negative values to specify gravitational forces that oppose the
                        coordinate direction.
                Specify amplification factor for the gravity load magnitude.
                    Note: The default  magnitude is specified as a ratio of 1G gravitational
                        load.
                Click OK.
