Spring Support
Set an elastic foundation at selected faces.
- On the Project Tree, open the Analysis Workbench.
                On the Analysis Workbench toolbar, select
 (Spring support).
             - In the modeling window, select desired faces.
                Select the coordinate system from the drop-down menu.
                Note: If needed, use the Create new button to create a new coordinate system.
 - Under Units, choose the Foundation Factor and Stiffness units.
 - Under Common foundations factors, choose an option from the drop-down menu.
                Define support stiffness values in one of the following ways:
Option Process Foundation factor Used to specify an elastic foundation. - Select the Foundation factor radio button.
 - Specify values for the X, Y, and Z directions.
Support stiffness Used to specify local support stiffness. - Select the Support total stiffness radio button.
 - Click OK.
