Bolt/Nut Tightening Loads
Available for blind bolts (bolt without a nut), bolt with nut/bolt on threaded rod, nut on generic post or handle.
- On the Project Tree, open the Analysis Workbench.
                In the workbench toolbar, click
 (Bolt nut
                    tightening).
             - Select the supported parts.
 - In the dialog, specify the Thread pitch.
 - Activate the desired Bolt/Nut tightening method radio button and enter values in the text fields.
 - Specify the Torque and Force units.
 - Click OK.
