Monitor the status of your jobs, filter the job view, view job details, monitor memory and core utilization, view
a list of job files, or perform job actions.
View and modify plot parameters after plotting a result file.
Click on the plot view.
The plot TOC is displayed with the applied template. Figure 1. Plot TOC
Modify the plotting parameters of the template.
Choose one of the following:
Click Save, the template is updated with the updated
parameters.
Click Set Template as Default, to set the template as a default
template.
Note: If a default template is set for a result file then RVS will display the plot result directly.
If the set default template doesn't match the result file, the Plot TOC
is displayed with a message to select another valid
template.
Click Save As, to create a new plot template.
Click Plot to view the changes in the plot result.
