Create a Plot from a Template
Create a plot using a template with the pre-populated parameters.
If you wish to view multiple plot result files using the same plotting parameters, streamline the process by creating a template to pre-populate the plot parameters.
RVS validates the selected template based on the plot parameters for the selected plot result file. If an invalid template is selected, you will see a message to select a valid template.
If a valid template is set as default for the selected result file then you will be
                directed to the plot view. Click
 to view and modify the
                plot parameters of the default template.
