HMIN_element_solver_writebar3_ynode()
Writes a 3-noded bar element with property idpool to HyperMesh using a node to define the local bar y axis.
void HMIN_element_writebar3_ynode (HM_entityidtype id, char elementtype, HM_entityidtype propertyid, HM_entityidtype node, double offseta[3], double offsetb[3], int pinsa, int pinsb, HM_entityidtype nodes[], HM_entityidtype collectorid, int propsidpool)
HyperMesh hminlib Function
- id
- The ID of the element.
- elementtype
- The type of the element, a user-defined value.
- propertyid
- The ID of the property to which the bar element should point.
- node
- The node that lies on the beam local y axis.
- offseta[3]
- The amount to offset the bar at end a.
- offsetb[3]
- The amount to offset the bar at end b.
- pinsa
- The degrees of freedom assigned to end a.
- pinsb
- The degrees of freedom assigned to end b.
- nodes[3]
- The nodes associated with the element.
- collectorid
- The ID of the collector where the bar element should be placed.
- propsidpool
- ID pool number of the property to which the element should point.
None.
