HMIN_element_writemass()
Writes a mass element to the HyperMesh database.
void HMIN_element_writemass(HM_entityidtype id, char elementtype, HM_entityidtype propertyid, double mass, HM_entityidtype systemid, HM_entityidtype nodes[], HM_entityidtype collectorid);
HyperMesh hminlib Function
- id
- The ID of the element.
- elementtype
- The type of mass, a user-defined value.
- propertyid
- The ID of the property assigned to the mass element.
- mass
- The mass of the element.
- systemid
- The system ID of the mass.
- nodes[1]
- The nodes associated with the element.
- collectorid
- The ID of the collector where the mass should be placed.
None.
