hwI3DViewCtrl Fit
Zooms into the dimensions of the curve in the 3-D plot.
hwI3DViewControl_handle Fit
HyperGraph 3D Tcl Modify
This command zooms in or out of the graph based on the dimensions of the curve in the plot. It differs from Zoom and CircleZoom in that it zooms to the curve’s dimensions, rather than the dimensions that you want. It differs from FitAllFrames in that it zooms to fit the curve itself, rather than the window.
hwi OpenStack;
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetViewControlHandle vc
vc Fit
Error
Returns success (0) or an error code.
Keywords
3D plot
Tcl
Modify
