hwI3DViewCtrl GetRotationAngle
Finds the angle of rotation.
hwI3DViewControl_handle GetRotationAngle
Tcl Modify
This command finds the angle of rotation, or a numerical value of how much the plot is rotated by, that the following functions use: RotateClockwise, RotateCounterClockwise, RotateUp, v, RotateLeft and RotateRight. The angle of rotation is preset at 1 degree. However, you can set a different angle of rotation with the function SetRotationAngle.
hwi OpenStack;
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetViewControlHandle vc
vc GetRotationAngle
Error
Returns a numerical value or an error code.
Keywords
3D plot
Tcl
Modify
