hwI3DViewCtrl SetOrtho
Sets the ortho of the 3D plot.
hwI3DViewControl_handle SetOrtho str
Tcl Modify
This command sets the view volume of the 3D plot using a string.
- str
- Inputs a string of six values, “xmin xmax ymin ymax zmin zmax”. This inputs the minimum and maximum for each axis to make the volume of the view a certain size.
hwi OpenStack;
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
w1 GetViewControlHandle vc
vc SetOrtho "0 5 0 5 0 5"
Error
Returns success (0) or an error message.
Keywords
3D plot
Tcl
Modify
