hwI3DViewCtrl SetRotationAngle
Sets the rotation angle.
hwI3DViewControl_handle SetRotationAngle angle
Tcl Modify
This command sets the angle of rotation (the numeric value) of how much the plot is rotated by, used by the following functions: RotateClockwise, RotateCounterClockwise, RotateUp, RotateDown, RotateLeft and RotateRight. The angle of rotation is preset at 1 degree. However, SetRotationAngle changes the angle to the value that you want to use.
angle
A user-selected number that represents the angle that you want to rotate by. A negative number does not make a difference to the rotation, for the functions that use this angle only rotate in one direction. Therefore, the functions use the absolute value of the negative angle value.
hwi OpenStack;
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
w1 GetViewControlHandle vc
vc SetRotationAngle 45
Error
Returns success (0) or an error code.
Keywords
3D plot
Tcl
Modify
