hwIProject CopyPage
Copies a page.
hwIProject_handle CopyPage page, append
Tcl Modify
This command copies a page in the project based on the page number you input.
page
The page number that you want to copy.
append
true or false.
true
Indicates the copy is added to a memory.
false
Indicates that the copy is not added to memory.
Multiple copies can be made and pasted at the same time, rather than copying and pasting each one individually.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj CopyPage 1 false
Error
Keywords
Tcl
Modify
