hwIProject IsDirty
Checks to see if the session has unsaved data.
hwIProject_handle IsDirty
Tcl Modify
This command checks whether the session contains unsaved data. If the project has unsaved data, then true is returned. If the data has been saved, then false is returned.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj IsDirty
Error
Success (true or false value) or an error message is return.
Keywords
Tcl
Modify
