hwIProject MovePage
Moves a page.
hwIProject_handle MovePage page, destination
Tcl Modify
This command takes a page and moves it to a new location. If you move a page to a higher page number, all of the pages below that number shift down. If you move the page to a lower page number, all of the pages above that number shift up (to make room for the moved page and to fill up the space that is left by the moved page).
page
The page number that you want to move.
destination
The page number that you want to move the original page to.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj MovePage 1 3;
Error
Keywords
Tcl
Modify
