hwIProject GetLayerHandle
Returns the layer for the given ID.
hwIProject_handle GetLayerHandle layer, layer_id
Tcl Query
- layer
- The layer handle to be set.
- layer_id
- The ID of the layer.
Error
Success (0) or an error code.
Adds a new layer to the project.
Adds a new page to the project's page list.
Copies a page.
Cuts a page.
Returns the active page index.
Returns a list of the layers on this page.
Returns the number of layers in the project.
Returns the number of pages in the project.
Returns the page for the given page name.
Returns the Templex object handle. This handle type is dependent upon the current client type.
Returns the window for the given ID.
Inserts a page.
Checks to see if the session has unsaved data.
Checks to see if the project is empty.
Moves a page.
Combines pages.
Pastes previously copied or cut pages.
Removes the given page from the project's collection.
Sets the given page as active.
Tcl Query
