Browsers provide a structured view of model data, which you can use to review, modify, create, and manage
the contents of a model. In addition to visualization, browsers offer features like search, filtering, and sorting,
which enhance your ability to navigate and interact with the model data.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Use the CFD 2D Mesh tool to generate hybrid grids containing hexa/penta/tetra elements in the boundary layer and tetra elements in the
core or fare field.
Automatically generate a mesh at the midplane location, directly from the input geometry (components, elements, solids
or surfaces), without first creating a midsurface.
The Rebuild tool streamlines the process of remeshing existing meshes to generate a new mesh with good quality and flow. The rebuild
mesh functionality utilizes the same parameter and criteria files used by BatchMesher to define the quality criteria and relevant mesh parameters. This algorithm saves significant time over the traditional
automesh and quality correction approach.
Adaptive wrap meshing is a useful utility to get a clean, water tight shell mesh out of 2D mesh containing several
intersecting parts and small gaps which do not need to be modeled.
Shrink wrap meshing is a method to create a simplified mesh of a complex model when high-precision models are not
necessary, as is the case for powertrain components during crash analysis.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Use PhysicsAI to build fast predictive models from CAE data. PhysicsAI can be trained on data with any physics or
remeshing and without design variables.
Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
General 2D Meshing
Use the General 2D Mesh tool to create 2D meshing with various algorithms.
Perform Batch Meshing
Use the BatchMesher tool to perform geometry feature recognition, cleanup and automatic meshing in batch mode for given CAD files.
Create CFD 2D Mesh
Use the CFD 2D Mesh tool to generate hybrid grids containing hexa/penta/tetra elements in the boundary layer and tetra elements in the core or fare field.
Create Panel Mesh
Use the Panel Mesh tool to generate and edit mapped panel mesh.
Create Rigid Body Mesh
Use the Rigid Body Mesh tool to create a quick mesh to represent the topology of a rigid object.
Midmeshing
Automatically generate a mesh at the midplane location, directly from the input geometry (components, elements, solids or surfaces), without first creating a midsurface.
Midsurface
Extract the midsurface of thin solids, and review and edit midsurface plates.
Apply Thickness to Midsurface
Use the Map Thickness tool to apply thickness values to shell elements on midsurfaced geometry.
Rebuild Mesh The Rebuild tool streamlines the process of remeshing existing meshes to generate a new mesh with good quality and flow. The rebuild mesh functionality utilizes the same parameter and criteria files used by BatchMesher to define the quality criteria and relevant mesh parameters. This algorithm saves significant time over the traditional automesh and quality correction approach.
Adaptive Wrap Meshing
Adaptive wrap meshing is a useful utility to get a clean, water tight shell mesh out of 2D mesh containing several intersecting parts and small gaps which do not need to be modeled.
EM Lattice Meshing
EM Lattice meshing is a method to create an axis-parallel mesh for 2D and 1D geometry input.
Shrink Wrap Meshing
Shrink wrap meshing is a method to create a simplified mesh of a complex model when high-precision models are not necessary, as is the case for powertrain components during crash analysis.
