Export various file types from the selected client to another
format.
During export you can write
information from a HyperMesh database to many finite element
formats. However, geometry data can only be written in IGES format.Use the Custom
option to export models using your own custom-built export translator, or export
models using a translator provided with the installation but which is not directly
accessible via the default Export file types.
Do one of the following:
Depending on the client you are using, the following file types can be
exported: models, geometry, solver decks, BOMs, connectors, H3D binary files,
curves, markers, output text, CSV tables, and custom data files.
In the Export File dialog, enter a name for the file and
save it to your working directory.
If needed, define any options in the Export Options dialog
and then click Export.
